Question About Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 08:13 PM   #1
Question about wires
Ok, this is a really basic and possibly dumb question:
I am installing track lighting in my kitchen. I took down the old lights today but will not have a chance to work on the new lighting for a few days. So I have a black and white wire hanging from my ceiling. If I just wrap electrical tape around the ends and tuck these back into my attic for a few days is this ok or is this a fire hazard?
snosurfa7 is offline   Reply With Quote
Old 09-22-2010, 08:36 PM   #2
Licensed electrician
Rewards Points: 1,486
You should not be able to tuck the wires into the attic. There should be a junction box installed.
You would be better to add some wire nuts instead of tape.
Old 09-22-2010, 09:16 PM   #3
Yeah...that is another thing I need to add...already had to do it with the other two kitchen fixtures - whoever did the wiring on my house (built in 1987) did not always put boxes where the wires run through the drywall (guess that would be a code violation). I ended up taping them off and then putting caps on the ends too - hope that will be ok for a day or two. thanks
Old 09-22-2010, 09:17 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I agree with Jim and you should have a junction box there for it and there is no otherway around unless the former luminaire was flourscent which I have see it from time to time.
I just don't really trust the tape 100% of the time just put a wirenut on each one and do it right.
Merci.
Marc
Old 09-22-2010, 10:47 PM   #5
Yup...the only lights that don't have a junction box are florescent...not quite sure why but that is being fixed anyway. Thanks for the replies, hopefully it will all be fixed up soon.
Old 09-23-2010, 06:50 AM   #6
Just call me Andrew
Rewards Points: 1,020
Some fluorescent fixtures can be used without a box...
Andrew
secutanudu is offline   Reply With Quote
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 11:20 AM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Running Wires From Basement Question reb162 Electrical 5 06-11-2010 04:08 PM
Is this normal? 20A circuit 20A wires feed 15A wires walt1122 Electrical 14 02-06-2010 02:44 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
