Question About Tandem Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 03:38 PM   #1
Rewards Points: 160
Question about tandem breaker
So I have a 15 AMP tandem breaker in the panel that has me a little concerned. The first circuit of the tandem breaker is powering the refrigerator drawing 8.50 AMPS. The second circuit on the tandem breaker is powering the garbage disposal and dishwasher. The GB is drawing 7 AMPS and the dishwasher is drawing 8.1AMPS.
My question is does the breaker share 15AMPS total between these 3 devices or does each circuit have 15 AMPS total?
word2yamutha is offline   Reply With Quote
Old 07-14-2013, 04:04 PM   #2
Rewards Points: 150
each tandem has a 12 amp rating but as breakers trip on heat it might serve you better to swap the fridge to a full size breaker.,
RIP EJT
usair is offline   Reply With Quote
Old 07-14-2013, 04:14 PM   #3
Rewards Points: 160
Not sure if this has any significance, but when I bought the house (its a foreclosure) the original dishwasher and the GB that came with the house didn't work. Not sure if that is due to a power issue or negligence to the appliances.
Old 07-14-2013, 04:39 PM   #4
Rewards Points: 6,652
It is to separate breakers of 15 amps each. Not a total of 15 amps in one unit. You are fine as long as you are not overloading that one leg too much, that you have that tandem on. Then you end up with a imbalance, that one leg has a higher draw on it, then the other.
Breaker question emh918 Electrical 12 06-30-2012 10:26 AM
Tandem breaker positions in main service panel elmaur Electrical 14 05-11-2012 02:28 PM
Question about tandem breaker mjarema414 Electrical 27 05-10-2012 08:39 AM
Question about replacing a circut breaker noviceshock Electrical 3 04-18-2012 02:19 PM
tandem 220v breaker? rknerem Electrical 5 01-21-2012 01:08 PM
