Question About Tandem Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 07:17 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
That is a 12/20 panel. The bottom eight spaces will accept tandem breakers.
Old 04-12-2012, 07:52 PM   #17
Rewards Points: 1,192
Speedy Petey, you mustn't have girls that run electric heaters and use hair dryers and curling irons.
bobelectric is offline   Reply With Quote
Old 04-12-2012, 07:56 PM   #18
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Or a wife that insists on being able to plug in a heater and one of those large hair dryers at the same time.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-12-2012, 08:02 PM   #19
Thanks speedy. We never trip breakers and have mixed wiring. My house was built in the 20's and it seems like the previous HO ran stuff everywhere. Lots of junctions and breakers that have multiple lights, outlets, appliances. I guess that's how they did back in the day. We did a lot of work in the last 4 years.
mjarema414 is offline   Reply With Quote
Old 04-13-2012, 05:41 AM   #20
Actually I do.
I added a receptacle for my daughter in her room for getting ready. It is not even dedicated, it's off the room's circuit.
Old 04-13-2012, 05:44 AM   #21
That will trip any breaker, even a brand new dedicated 20A line.
We are not crazy/desperate enough to run space heaters, even though the heating system in my home is not what you'd call optimal.
Old 04-26-2012, 11:21 AM   #22
12/2 to 14/2 wire
Thanks again. I need to bring this post back because I had one more question. I ran 14/2 wire for a few outlets from the junction which has 12/2 wire on a 20amp breaker. This is dedicated breaker for my attic. Basically the only thing on it is 2 lights and 4 outlets. I read where going from 12/2 wire to 14/2 wire on a 20amp breaker could be a fire hazard if something plugged in draws too much. Is this true? Someone suggested changing out the breaker to 15amp. Thanks.
Old 04-26-2012, 11:34 AM   #23
Licensed electrician
Rewards Points: 1,622
The 20 amp breaker would not trip in time to protect the 14 gauge wire. You can change the breaker to a 15 amp and loose 1/4 of the circuit capacity or change the #14 to #12.
mjarema414 (04-26-2012)
Old 05-08-2012, 02:13 PM   #24
Pete, will the beaker I'm pointing to in the picture on previous page accept a tandem. I didn't get to it yet but the way the spaces are numbered and how it looks on the panel doesn't make sense. Not sure if the breaker I want to switch is considered on of the bottom 8. Thanks for you help.
Old 05-08-2012, 02:19 PM   #25
Any position below the top two breakers will accept a tandem breaker.
Look at the label, any space with only one number is not a tandem. spaces with two numbers will accept tandems.
mjarema414 (05-10-2012)
Old 05-08-2012, 05:18 PM   #26
rrolleston's Avatar
Been lucky so far with the bathroom rewire lighting on one circuit shared with kitchen hallway and laundry room lighting and a dedicated 20 amp circuit for next to the sink. But it's not a large space heater just enough to take the chill off when she takes a shower.
Before this there was all that lighting along with receptacles in bathroom one whole bedroom on one 15 amp circuit. Now to find an good and safe way to have our bedroom on it's own circuit instead of being tied to the living room and dining room and our upgrade will be complete.
Old 05-08-2012, 08:46 PM   #27
I=E/R
a7ecorsair's Avatar
Take the tape off the panel and see what is embedded in the cover for numbers. I think the top four spaces have been cheated.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 05-10-2012, 07:39 AM   #28
I think your right. Will do. This might be why I was confused. The previous homeowner must have done this. Could this potentially be a fire hazard? I've been in this house since 2006 and haven't had any issues with blowing fuses.
tandem 220v breaker? rknerem Electrical 5 01-21-2012 12:08 PM
Square D breaker question Minus08 Electrical 11 01-20-2012 04:17 AM
Tandem breaker use pomelo Electrical 3 03-18-2010 08:17 AM
tandem breaker MikeyP Electrical 11 06-29-2009 01:48 PM
tandem question Shanarchy Electrical 1 06-14-2008 07:33 AM
