Question About Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 09:12 PM   #1
Question about sub panel
Hi, I need help figuring out what size breaker and cable to run to a sub panel.
The sub panel will feed two 1000 watt light fixtures wired at 220 ,
i will need another 20 amp breaker for another light, and then about 10 outlets for some fans and stuff, so i need to know what size breaker for my main panel, and what size cable to run to the sub panel? I imagine i would just want to run 100 amp with 2/3 but i wanted to make sure .
Ryan
lilryry is offline   Reply With Quote
Old 07-28-2011, 09:15 PM   #2
Electrical Contractor
kbsparky's Avatar
Overkill, big time.
-KB
Old 07-28-2011, 09:16 PM   #3
well thats why i am posting because i dont know what to use. I do want to make sure its safe.
Ryan
Old 07-28-2011, 09:20 PM   #4
i think each 1000watt light needs its own 30 amp right? so thats 60 righty there, then i have one more big light that needs a 20 thats 80, and then the outlets for the fans and stuff. thats why i said 100
Old 07-28-2011, 09:26 PM   #5
Licensed electrician
Rewards Points: 1,622
The 1000W lights at 240 volts are less than 5 amps each.
Old 07-28-2011, 09:40 PM   #6
I=E/R
a7ecorsair's Avatar
You are doing the math wrong.
Unless you have plans for a lot more load, like a shop with power tools, a 60 amp sub will have plenty of capacity with room to spare.
a7ecorsair is offline   Reply With Quote
Old 07-28-2011, 10:46 PM   #7
Rewards Points: 1,016
A 100 amp subpanel fed via a 60 amp breaker is a common setup for a shop or similar - usually ample power, room for expansion, and cost effective to implement.
____________
Vince
Old 07-29-2011, 09:33 AM   #8
Ryan
Sounds like someone is building a grow house...hopefully nothing illegal is being planted ???
acer is offline   Reply With Quote
Old 07-29-2011, 10:03 AM   #9
what size cable do i need from the main panel to the sub panel?
Old 07-29-2011, 10:22 AM   #10
It depends on how far away the sub panel is from the main.
Old 07-29-2011, 11:04 AM   #11
its only about 15 feet from the main panel
Old 07-29-2011, 11:30 AM   #12
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What size breaker?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-29-2011, 11:32 AM   #13
jbfan's Avatar
Rewards Points: 482
6/3 with a ground!
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Electric panel enclosure question globus999 Electrical 6 11-23-2010 09:30 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
