Question About Running Romex In Attic Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 11:44 AM   #1
Rewards Points: 156
question about running romex in attic ceiling
I'm finishing off my attic and I have a question. Is it generally ok to run Romex in the void of an A-frame attic? I'm planning to insulate the entire thing so there will be fiberglass insulation between all the ceiling joists. I've run a bunch of IC recessed fixtures along the flat part of the ceiling as shown in my quick sketch below. I guess I'm wondering whether I should have used conduit. I have plastic attic vents running from the bottom soffit up to the void created by the ceiling joists and I installed a ridge vent at the top for air flow. I figured since I could run Romex without conduit in my walls, the ceiling should be the same thing right?
jayp is offline   Reply With Quote
Old 03-18-2009, 12:04 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 494
You are fine. Just remember to staple the wire at every 4.5 feet, and where it enters into the light junction box.
jbfan is online now   Reply With Quote
Old 03-20-2009, 12:43 PM   #3
Rewards Points: 174
Thats how the pros do it. The less drilling, the better.
Old 03-20-2009, 12:54 PM   #4
That's dumb.
It's code, but it's dumb.
I guess they expect leprecons to get in there some day and pull on the cable . There is no access to an "attic" like this. It's used for insulation and mechanical systems.
220/221 is offline   Reply With Quote
Old 03-20-2009, 12:55 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jayp,
Thanks for the excellent illustration. How did you do it?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-20-2009, 01:06 PM   #6
jbfan's Avatar
Rewards Points: 494
Originally Posted by 220/221 View Post
That's dumb.
We only advocate code correct installations here!
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 05:08 PM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 11:52 AM
