-   -   question about running romex in attic ceiling (http://www.diychatroom.com/f18/question-about-running-romex-attic-ceiling-40604/)
jayp 03-18-2009 11:44 AM
I'm finishing off my attic and I have a question. Is it generally ok to run Romex in the void of an A-frame attic? I'm planning to insulate the entire thing so there will be fiberglass insulation between all the ceiling joists. I've run a bunch of IC recessed fixtures along the flat part of the ceiling as shown in my quick sketch below. I guess I'm wondering whether I should have used conduit. I have plastic attic vents running from the bottom soffit up to the void created by the ceiling joists and I installed a ridge vent at the top for air flow. I figured since I could run Romex without conduit in my walls, the ceiling should be the same thing right?
http://lh4.ggpht.com/_Ueee7UTcIdg/Sc...s800/attic.jpg
jbfan 03-18-2009 12:04 PM
You are fine. Just remember to staple the wire at every 4.5 feet, and where it enters into the light junction box.
J. V. 03-20-2009 12:43 PM
Thats how the pros do it. The less drilling, the better.
220/221 03-20-2009 12:54 PM
That's dumb.
It's code, but it's dumb.
I guess they expect leprecons to get in there some day and pull on the cable :yes:. There is no access to an "attic" like this. It's used for insulation and mechanical systems.
PaliBob 03-20-2009 12:55 PM
Jayp,
Thanks for the excellent illustration. How did you do it?
jbfan 03-20-2009 01:06 PM
Originally Posted by 220/221 (Post 247399)
That's dumb.
We only advocate code correct installations here!:whistling2:
