Question About Recessed Under Cabinet Lighting-outdoor? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 09:52 AM   #1
Rewards Points: 212
Question about recessed under cabinet lighting-outdoor?
I want to install 6 recessed under cabinet puck style lights outside in the soffets of my house for accent lighting.
I have not been able to find some that are for outdoor use. I've had plenty of people tell me they would work fine using the indoor ones since they would be covered. Will the indoor ones work for this type of install?
Also, they are going into the plastic type soffet. Will this melt if they were to get hot like halogen.
Here's an example of "about" what I'm picturing going outside. I've seen some better examples at Lowes but cannot find them online.
http://www.lowes.com/lowes/lkn?actio...-WH&lpage=none
or
http://www.lowes.com/lowes/lkn?actio...98P&lpage=none
If you have any ideas on what I can use or recommend a way to install this please let me know.
I was thinking that I could find some Low Voltage recessed round puck-like lights that had a small wall to keep light focused at a certain area. Then I could easily hook them up to a timer to turn on with my outdoor light I have on the Palm trees.
imola ghost is offline   Reply With Quote
Old 04-16-2009, 09:54 AM   #2
Remodeling Contractor
For this use indoor recessed lights are fine. But you need exterior rated lamps. Halogen are too hot for proximity to plastics. Try to find LED lights that will fit in the same fixture.
Old 04-16-2009, 10:18 AM   #3
Rewards Points: 212
I'm thinking that the LED's would not be illuminate 8-10 feet.
Old 04-16-2009, 10:38 AM   #4
you can buy them to provide the same lumens (light output)
Old 03-08-2011, 03:02 PM   #5
I think you should not dwell from sites to sites. I got one best site best kitchen lighting for you to get your ultimate choice. I can say about my two friends at least who got their best suggestions from it. Good luck...
andrewdigger is offline   Reply With Quote
Old 03-09-2011, 02:33 AM   #6
You may visit this blog and I hope you will get the right answer......
Recessed Cans for Outdoor Lighting, Spacing jamiedolan Electrical 7 04-13-2009 04:18 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
Confused.....Halo H7ICT Recessed Lighting Question tigerbalm2424 General DIY Discussions 5 01-09-2008 07:21 AM
