Old 01-03-2010, 09:23 AM   #1
Question about outdoor lighting
I am going to install 2 outdoor lights and I will be using an orange outdoor power cord, (do not want these permanent). The lights have a BLACK wire and a WHITE wire. I will be cutting the power cord and splicing the lights in. What wires do I need to use?
thanks
LAFORD1986 is offline   Reply With Quote
Old 01-03-2010, 09:26 AM   #2
Master Electrician
JohnJ0906's Avatar
thanks
Not legal.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-03-2010, 09:50 AM   #3
Where do you intend to tap these into? If you don't want them permanent, why not leave the plug on and simply plug them into an outlet?
While I cannot confirm this illegal, it sure sounds flakey and I would tend to believe JohnJ0906 is correct. Could you not add an outlet at the proper location and simply plug these in?
oberkc is offline   Reply With Quote
Old 01-03-2010, 10:26 AM   #4
Licensed electrician
John is correct for a couple of reasons. Cord is not to be used in place of permanent wiring. Also the fixtures are not listed for use that way.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
