Question About NMD-60 Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2013, 04:35 PM   #1
Rewards Points: 150
question about NMD-60 cable
I have a question about an NMD-60 cable in my house.
as you can see from the picture, the cable enters the basement through the ceiling (top left of pic) , and goes into the next room (cold cellar) where it is attached to a ceiling light with a pull chain. From there, the cable enters the house again into other receptacles (bottom left of picture).
1. Since i will be closing of the ceiling in the cold cellar soon, I wanted to know if it was a good idea to change the cable into BX as this is right under a porch?
2. The existing cable coming from the ceiling is not long enough to reach the floor for a receptacle, but is long enough to reach light switch height. The question is, is it possible to run the existing cable to a new light switch in front of the door, and also have another cable running from the light switch to receptacles along the wall?
gramps416 is offline   Reply With Quote
Old 11-13-2013, 07:28 PM   #2
joed's Avatar
Rewards Points: 13,752
Yes that is possible. I think I would pull both those cables back to the new light switch box and run a new cable for light power from the switch box to the light.
Old 11-14-2013, 08:26 AM   #3
Rewards Points: 150
The reason why i am confused, is most light switches don't have a line and a load terminal on them.
Is there a special type of light switch to buy, or is it wired differently?
How many BX cables would need to go to the cold room from the ligth switch. Just one?
Old 11-14-2013, 08:32 AM   #4
joed's Avatar
No you use pigtails. Connect the incoming and outgoing power wires and a short 6" pigtail wire of the same colour and gauge with a wire nut. Connect the pigtail to the switch.
Unless you want something more than lights you only one cable for lights.
Old 11-14-2013, 05:15 PM   #5
Oso954's Avatar
Rewards Points: 1,670
With simple single pole switches, they are either open or closed. Line and load don't matter because they will work either way.
Oso954 is online now   Reply With Quote
Old 11-15-2013, 11:47 AM   #6
Rewards Points: 150
If i use pig tails, is this how it should be wired? (see picture).
obviously i didn't actually draw in the maurettes.
Old 11-15-2013, 07:35 PM   #7
joed's Avatar
Close but the neutral does NOT connect tot he switch. Only the black pigtail and black wire to the light go to the switch. The two whites connect together but no pigtail and no connection to the switch.
Old 11-16-2013, 10:21 AM   #8
Rewards Points: 150
like this then?
Old 11-17-2013, 08:17 PM   #9
Rewards Points: 150
which two whites are you reffering to?
is the previous revised drawing correct?
Old 11-17-2013, 08:49 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
The neutral from the light connects to the neutrals in and out. The black for the light connects to the switch.
Old 11-18-2013, 08:27 AM   #11
joed's Avatar
No the light neutral(white wire) dos NOT connect to the switch. More like this.
The Following 2 Users Say Thank You to joed For This Useful Post:
47_47 (11-18-2013), jbfan (11-18-2013)
Old 11-18-2013, 03:34 PM   #12
Rewards Points: 150
great stuff.
Is this box big enough? 16 cu inch. My calculations came out to 18 cu inch for 3 cables (simplified)
thanks
Old 11-18-2013, 04:09 PM   #13
Licensed electrician
Rewards Points: 1,892
All grounds only count as one. The device counts as two.
A #14 is 2 cubic inches while a #12 is 2.25 cubic inches.
Old 11-19-2013, 09:44 AM   #14
Rewards Points: 150
i count
1 for all grounds
1x2 = 2 for 2 clamps in use inside the box
2 for the switch
3 for all black current wires
14/2 wire used X2
=16 cu inches.
I think that is correct. I always wondered about clamps. Does it mean the clamps in use in the box?
Electrician best practice questions mudworm Electrical 32 11-12-2011 01:59 PM
M C cable question stevo1213 Electrical 8 10-10-2011 08:10 AM
Low volt question (RG-6 cable & shorts) Alan Electrical 11 03-23-2011 11:56 PM
Underground Cable Question Livewire78 Electrical 7 12-09-2009 12:15 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
