Question About Mixing 4-pin CFL Bases And Lights Wattages - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 03:02 PM   #1
Tinkerer
slowrolling's Avatar
Question about mixing 4-pin CFL bases and lights wattages
I have recessed lights in the kitchen running triple tube CFL's which are the 4 pin style.
The bases are of type GX24q-3 which are rated for 26w bulbs and are currently running 26w bulbs.
I was wondering if I could run 18w bulbs in them without a problem (like you can normal incandescent). Or must it be 26w?
Thanks!
slowrolling is offline   Reply With Quote
Old 07-18-2010, 03:06 PM   #2
I=E/R
a7ecorsair's Avatar
You can run a lower wattage without problems. The rating is the max wattage.
a7ecorsair is offline   Reply With Quote
Old 07-18-2010, 05:46 PM   #3
The ballast is in the bulb (maybe not for the pin types !!)
So its easy to swap wattages
Old 07-18-2010, 10:58 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Woah .,, Woah.,,
Before you go this route please verify the ballast info if this is a hardwired CFL unit.
You can not install smaller wattage flourscent bulb without checking the ballast info.
If they can allowed smaller wattage bulb you are good to go.
Dave just give you a head up this type of socket as OP describing that is hardwired recessed luminaire so the OP have to pull the can sleeve down to see the ballast info I know it will not be easy but that is the only way the OP can verfiy the ballast info.
a7ecorsair.,
Not always the case it depending on which type of ballast if electronique or magatinc ballast if electronique it may have multi wattage rating but not on magatic they only rated for single wattage most case unless they stamp the info on that.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Scuba_Dave (07-19-2010)
Old 07-18-2010, 11:02 PM   #5
Interesting....all of my 4 pin recessed have the ballast built into the bulb (maybe not!)
I was unaware that any fixture had the ballast for the CFL bulbs
Or that any CFL bulb was available without a ballast built in
Old 07-18-2010, 11:13 PM   #6
Dave .,
Just hit this link as I provide to ya.,
http://www.junolightinggroup.com/pro...ontent_extra_9
That is resdentail line and that do have hardwired ballast in there.
Merci.
Marc
Scuba_Dave (07-18-2010)
Old 07-18-2010, 11:17 PM   #7
Now I need to 2x check my CFL recessed cans...single CFL -13w
I haven't had to change any bulbs...yet
Old 07-18-2010, 11:19 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I have never installed or worked on a pin type CFL that had the ballast in the base.
Old 07-18-2010, 11:22 PM   #9
I have see it but only with either G10 or G26 bipin base.
Merci.
Marc
Old 07-19-2010, 01:16 PM   #10
Tinkerer
Haven't bought the lower wattage yet. I pulled down the baffle and reflector and this is the model I have:
http://www.iuseelite.com/pdf/B5PLIC_BAFFLE.pdf
Spec sheet says "Accommodates (1) 9W, 13W, 18W or 26W compact fluorescent lamp"
So looks like I should be good to go, Anything else I should be looking at?
Old 07-19-2010, 02:03 PM   #11
nap
You talking to me?
nap's Avatar
my pdf reader isn't working right so I can't read the link but, if that label is on the ballast, then you are ok. If it is on the housing, you need to check the ballast to see what it will drive.
Old 07-19-2010, 03:48 PM   #12
I just checked & mine have ballasts marked for 13w bulbs only
Good to know...I think 13w or less would be all that would fit in mine
Old 07-20-2010, 12:52 AM   #13
The safest way is check the ballast info many time it will stamp the wattage on it.
If it have couple wattage listed then you should be ok.
But if you install 18 watt bulb and still look very bright then you have to revert back to 26 watter the reason why I mention that due you can overdrive the bulb and it will shorten the life of it.
Merci.
Marc
