Question About High Hat - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 09:26 PM   #1
Question about high hat
Hello. I have a quick question. I am installing 6 halo recessed lights in my basement and I have to cut out the tiles to meet the lights. My question is , with the springs that go from the baffle trim to the actual interior of the high hat, can I use wire that I used for my drop ceiling to bring the baffle trim down further to meet the drop ceiling tiles?
Thanks again.
[/IMG]
Jperrotta is offline   Reply With Quote
Old 01-11-2013, 09:28 PM   #2
Old 01-11-2013, 09:31 PM   #3
Licensed electrician
Rewards Points: 1,464
The fixture should extend through the tile. You should have mounted the spreader bars on the ceiling Tees, not the framing.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
brric (01-11-2013), k_buz (01-12-2013), NJMarine (01-12-2013)
Old 01-11-2013, 09:51 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,158
Can you do it ?
Yes !
But it might effect its listing !
Could also effect home insurance
as it is not used strictly as intended.
So it's a definate maybe !
dmxtothemax is online now   Reply With Quote
Old 01-12-2013, 06:27 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No, you cannot do it. As stated above, you need to mount the fixtures to the ceiling grid.
1/2HP motor: start on low, or high? tylernt Electrical 3 11-16-2012 11:48 AM
High particles, high co2, and high relative humidity robotman2009 HVAC 15 07-26-2012 07:50 AM
Changing High Pressure Sodium bulbs question rotteux Electrical 11 07-19-2011 10:09 PM
Mowing High question Breakthecycle2 Landscaping & Lawn Care 2 06-08-2011 07:49 PM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 05:55 PM
