Question About A Generator Amperage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2009, 12:17 PM   #1
question about a generator amperage
I have a 12kw 120/240 generator with an amperage rating of 100/50. my question is ... can I run the 100 amps at 120 volts and the 50 amps at 240 volts at the same time?
thanks
pnutzhome is offline   Reply With Quote
Old 11-10-2009, 12:47 PM   #2
12kw = that's all you have
You can pull either of totals listed or a combo to make 12 kw....no more
Ya can't get what ya ain't got
Old 11-10-2009, 02:30 PM   #3
Just so you know for future reference Power=Volts*Amps, I'm sure everyone will chime in with power factors and stuff but for basic stuff just use that formula.
Salem747 is offline   Reply With Quote
Old 11-10-2009, 03:13 PM   #4
Not for long
Old 11-10-2009, 08:09 PM   #5
Idiot Emeritus
Rewards Points: 1,492
If the gen is connected 120/240, you'll have 50 amps available at each of the two hot legs. This can be at 120 volts, 240 volts, or any combination, but at no point can there be more than 50 amps.
If the gen is connected 120 volts, you'll have 100 amps available. Since you now have only two wires, the two hot legs will add.
Rob
micromind is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
