-   -   Question about exposed junction box on floor & code (http://www.diychatroom.com/f18/question-about-exposed-junction-box-floor-code-40691/)
BradG 03-19-2009 05:05 PM
This galvanized junction box is in the middle of our closet floor. The wiring and associated piping was originally in a wall that we move out two feet to make a walk-in. The floors of this building are stone and concrete so when the electrician started whining about what to do with the wiring, I told him not to sweat it since this area was to have hanging clothes above it and this was the result.
What you're looking at is where two steel pipes come up out of the floor. One comes from the fuse box (where the red & blue wires come up on the right) and one (where they disappear on the left), going to some in-wall outlets.
Now our plans have changed and this junction box is going to be in the middle of an access area. To lower it's profile in order to build a shorter "hump" around it, I was hoping to use this box on the right along with the thinner, square routing that comes with it.
My questions are, is this going to be to code? What if I don't use the metal back plate (so the bottom surface is the exposed concrete, below the parquet), is that a safety, non-code, issue? Finally, is there any issue with me snipping the red & blue wires and capping them to make it easier to remove the box?
The red & blue wires go to outlets in the bedroom wall or they may be the new wiring put in place when we added a dedicated 110 line for the air conditioner. the capped wires go to the new closet wall which has an outlet and one overhead light.
http://pix.soundwag.com/web/closet_wiring.jpg
220/221 03-19-2009 05:41 PM
No.
Can you access under the floor to reroute the conduit/wiring?
Ultrarunner2017 03-19-2009 06:52 PM
I believe it is a violation of the code to have any sort of obstruction in an occupied area (closets included).
It would also be a violation of the code to put the box face down without its cover, using the stone/concrete as the "cover".
Was this box located inside the wall space prior to moving the wall?
if so, that was a violation.
I am sorry, but I would not accept anything less than rewiring the circuit, moving the J-box to an acceptable location; one where its cover can be removed for access without removal of any building part (wall, floor, ceiling, etc).
As 220/221 asked; Do you have access from below?
FW
BradG 03-19-2009 07:10 PM
No access from below. It's poured concrete with with 2-3" stones in it. I've ruined my Milwaukee hammer-drill when working on the bathroom floor.
The current J-box situation has already been inspected and passed code. Originally, everything was in the floors or (concrete block) walls. There was no J-box before.
I'm just trying to figure out if I can reduce it's presence safely but I guess not.
rgsgww 03-19-2009 07:35 PM
Is it possible to run new wire? I mean, you could just chisel some of the concrete around the old conduit and cut it off, then just fill it up with some more concrete.
BradG 03-19-2009 08:13 PM
Well yeah, that's what I should have had them do originally. It would be a pretty major pain in ass now that renovations are over. This is an apartment complex.
J. V. 03-20-2009 01:08 PM
I cannot delete my post. Sorry.
Scuba_Dave 03-20-2009 01:22 PM
Any hump someone is going to trip over
I'd build a storage chest & put a new junction box facing out that would be accessible
BradG 03-20-2009 01:50 PM
Well how about a good joke, or at least a fun quote then? :wink:
J. V. 03-21-2009 12:05 PM
Okay. Joke.
(Question) What do fat girls and mopeds have in common?
(Answer) They are both fun to ride until a friend see's you. :)
Quote: "Just because you are swimming upstream and against the current, does not mean you are going the wrong way". :yes:
