Question About Electrical Shock Chewing Cords - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 12:52 PM   #1
Question about electrical shock chewing cords
I am going to be watching a young cat soon who likes to play with electric cords. I probably should know more about electrical safety than I do, but I want to cat-proof my house. I know that if I unplug a lamp, appliance, etc. the cord, if chewed, should not give the cat a shock. However, I do not know if a lamp, etc. would be safe left plugged in, but not turned on. Is there the possibility of electrical shock from chewing a cord if something is plugged into the wall, but is turned off? Thank you!
sljacobs is offline   Reply With Quote
Old 02-24-2010, 12:55 PM   #2
Just call me Andrew
Rewards Points: 1,020
Yes, if a cat chewed through a lamp cord that was plugged in, it would get shocked regardless of the on/off position of the lamp. The cord always has electricity in it, it is cut off at the lamp switch.
Andrew
secutanudu is offline   Reply With Quote
Old 02-24-2010, 01:06 PM   #3
Learning by Doing
Leah Frances's Avatar
ALSO, if kitty is chewing un-plugged electrical items they should NOT be plugged back in until they are inspected for ANY damage. And really, if Mr or Mrs Kat is going to town on electrical cords they can be damaged but the damage can be difficult to see, putting you and the cat in danger.
Bottom line. Kitty MUST be stopped. Wires must be protected. Good luck!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-24-2010, 01:56 PM   #4
Rewards Points: 252
I'd give the cat a nice, live 220V cord to chew on. That should solve the problem quickly!
Seriously, though: If I was hosting such a cat, I'd keep it in a cordless room, or in a kennel box when unattended. Not worth the risk to cat or home (i.e., you and your family) to risk chewed-up electrical lines!
Itsdanf is offline   Reply With Quote
Old 02-24-2010, 02:43 PM   #5
wire loom works great for this, i put it on most of my cords when my cats were kittens
naehring2000 is offline   Reply With Quote
Old 02-24-2010, 04:10 PM   #6
Rewards Points: 180
You can also rub Tobasco sauce on all of the wires the cat has access to. It probably won't want to chew the wires after the first few tastes.
I never had a problem with our cats or dog chewing wires, so I haven't personally tried the Tobasco trick.
Good luck!
Barb
gma2rjc is offline   Reply With Quote
Old 02-24-2010, 04:26 PM   #7
Rewards Points: 590
What if kitty is cajun?
operagost is offline   Reply With Quote
Old 02-24-2010, 06:47 PM   #8
Rewards Points: 180
It'll just add a little spice to his life.
Old 02-24-2010, 07:17 PM   #9
Thanks to all for the helpful information. And also for the laughs!
Old 02-24-2010, 10:37 PM   #10
Rewards Points: 1,016
Just tell the cats not to chew on the electric cords...
Old 02-24-2010, 11:48 PM   #11
Yah it's indeed the case that anything plugged in has current in the wires. There's two wires - a hot and a neutral - and the hot ALWAYS has current in it, and the switch on the device or in the cord switches the hot on and off to the device. If you were to take apart your lamp and touch the point where the cord connects to the socket, even if the switch was off, you'd get a shock if you touched the hot.
Thankfully none of my cats ever were cord-chewers.
fm
fdmillion is offline   Reply With Quote
Old 02-25-2010, 12:18 AM   #12
" Euro " electrician
frenchelectrican's Avatar
With my cats I use either Pepper or Tobasco sauce one of the two they will get the message across with Pepper they will snezze few time but with Tobasco sauce they will really give up fast.
Merci,
Marc
Old 02-25-2010, 10:36 AM   #13
Rewards Points: 720
fm
The hot wire always has voltage on it. The switch interrupts the current (no current flow other than leakage).
Mark
busman is offline   Reply With Quote
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Electrical Switch Question Boatnuts Remodeling 2 03-30-2007 06:56 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
