Question About Dual Main Panels - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 08:32 AM   #16
I=E/R
a7ecorsair's Avatar
Originally Posted by Code05 View Post
Typical idiot at Lowes. They screw up this question all the time.
Lowes or HD and even my farm store say #2 AL is good for 100 amps and they are not totally wrong, but this is a two sided problem... The electrician (read as DIYer) should also know what should be required for his project.
OP - Since the wire is cut, the easy thing to do is as Speedy said, buy a 90 amp breaker instead of a 100 amp. The sub-panel can still have a 100 amp disconnect breaker.
a7ecorsair is offline   Reply With Quote
Old 09-10-2011, 08:39 AM   #17
Code05's Avatar
Rewards Points: 1,104
If the OP is under 2008, I think he will need a 80 amp breaker for #2 SER.
Code05 is offline   Reply With Quote
Old 09-10-2011, 08:41 AM   #18
I=E/R
a7ecorsair's Avatar
Originally Posted by Speedy Petey View Post
I have to say off the record, MANY places still allow the use of #2SER for a 100A sub-panel. No one around here gives it a second thought.
#1SER is nonexistent around here, and 90A breakers are lame.
Interesting...
My state electrical inspector doesn't allow it.
So as far as this project goes, should the OP contact the inspector first and get a ruling or wire it up and see what happens at inspection time?
Old 09-10-2011, 09:44 AM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
I know right. That STUPID simple one term code change that messed things up. How lame.
Old 09-10-2011, 09:46 AM   #20
Interesting...
That's why I said "off the record". I couldn't in good conscience directly recommend it since it is a local (and contentious) issue.
Luckily my state does not have "state" inspectors. Most I have ever heard of were on power trips.
Old 09-10-2011, 10:09 AM   #21
Code05's Avatar
Agreed.
Old 09-10-2011, 11:09 AM   #22
I=E/R
a7ecorsair's Avatar
If it is USE-2 that he will use will that change anything? It is a detached garage so I'd guess the cable will go in a trench.
Old 09-10-2011, 05:25 PM   #23
OK, here's the update.
Yes, Corsair, I put in the conduit when we first moved in and redid the driveway. I'm just not getting around to doing the wiring.
Went back to Lowes and confirmed with them, and also with 2 other independent electricians, that 2-2-2-4 aluminum is standard here for wiring 100 amp subpanels. They all told me they don't see anything else, ever. I confirmed the 100 amp/90 amp situation too, and they all assured me the inspector is going to expect to see a 100 amp breaker, so that's what I got. If anyone raises a stink later, I can easily swap out the one in the box for a 90. I really don't need the 100 amps in the garage anyway, it's more of a future-proof kind of thing.
Also, Lowes had the Squre-D neutral lug in stock, so that was an easy fix.
Thanks for all of the help and input. It makes it easier when you can ask first and not have to redo it for the inspector.
drodge is offline   Reply With Quote
Old 09-10-2011, 06:10 PM   #24
Master Electrician
Rewards Points: 3,916
If you are using SER cable it is not rated for underground use even in conduit.
brric is offline   Reply With Quote
Old 09-10-2011, 06:49 PM   #25
Electrician
SD515's Avatar
Rewards Points: 504
...Went back to Lowes and confirmed with them, and also with 2 other independent electricians, that 2-2-2-4 aluminum is standard here for wiring 100 amp subpanels. They all told me they don't see anything else, ever. I confirmed the 100 amp/90 amp situation too, and they all assured me the inspector is going to expect to see a 100 amp breaker, so that's what I got...
This arises because many donít understand 310.15(B)(6) [310.15(B)(7) in 2011 NEC]. Though local jurisdictions can approve or disapprove 100A on #2 AL, many inspectors and electricians donít know or understand the section. My opinion.
Kyle
dual zone to single zone question cpifer Off Topic 10 09-14-2010 02:41 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 07:26 PM
Main Service Disconnects rwlawrence Electrical 5 11-04-2008 10:46 AM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 08:04 AM
