Question About Dimming A Bathroom Heat Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 06:26 PM   #1
Rewards Points: 206
Question about dimming a bathroom heat lamp
I just installed a bathroom heat lamp (thanks to the help I received on this forum) and I would like to know if I can put a dimmer on it. The instructions say that I cannot because it has a fan that blows the heat from the lamps down into the room. However, you can unplug the fan, which is what I would do. Also, since it's warmer out, I will be using 45 watt bulbs instead of the 250 watt heat lamps, but I would like to be able to dim them. I think that I should be able to unplug the fan and then dim the bulbs, but would like confirmation. Thanks a lot.
joeg679 is offline   Reply With Quote
Old 04-27-2011, 06:42 PM   #2
Rewards Points: 1,418
Yes you can disconnect the fan and then use a dimmer for the (incandescent) heat lamps. I would not recommend installing a dimmer and also using the fan from time to time with the dimmer all the way up because it is too easy to forget and fry the dimmer or the fan.
But generally putting a dimmer on a heat lamp is a useless thing to do. Heat lamps don't give off that much heat and when you would turn on a heat lamp, you want all the heat you can get.
The Following User Says Thank You to AllanJ For This Useful Post:
joeg679 (04-27-2011)
New Bathroom Drain Question militaryman Plumbing 1 01-06-2011 10:09 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 01:05 PM
heat pump question David from MD HVAC 3 02-01-2010 09:42 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
