Question About Clock Outlets And/or Recessed Plugs - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 04:35 PM   #1
AWK
Unhappy
Question about clock outlets and/or recessed plugs
Hey - question everyone.....Do they make a recessed plug (like a clock outlet for hiding the plug and cord behind a clock or picture) big enough for an a/c adapter? I'm putting an alarm system in my condo and would like to put a recessed plug behind the keypad panel to fit the a/c adapter. Any ideas? thanks.
AWK is offline   Reply With Quote
Old 06-13-2011, 04:53 PM   #2
Rewards Points: 6,652
No, not for a transformer to convert AC to DC, if that is what you are talking about.
Old 06-13-2011, 05:07 PM   #3
AWK
Smile
Recessed Plug
I need a recessed receptacle thats deep enough to hold the 1 1/2" deep, 3" long and 2" wide adapter plug (like you plug in the wall from an electric shaver). The ones I have seen are not that deep or wide enough to conceal the adapter and make it flush with the wall. Let me know if that makes sense.
Old 06-13-2011, 05:37 PM   #4
Still no, there is nothing out there that will accept a transformer. The reason they do not want the transformer behind the panel, is because they get warm, and need to be able to be disconnected from the AC power when needed for maintenance, or replacement. Placing behind the panel kind of makes it difficult to perform said activities. If you are worried about someone pulling the plug, that is what the battery back up is for.
Old 06-13-2011, 05:40 PM   #5
Lic Elect/Inspector/CPO
Most times the transformewr is located near the actual alarm panel.
NJMarine is offline   Reply With Quote
Old 06-13-2011, 05:49 PM   #6
Electrical Contractor
kbsparky's Avatar
Mount it inside the alarm panel. A simple handy box with an outlet in it is usually sufficient.
-KB
Old 06-13-2011, 05:49 PM   #7
AWK
Yeah, I was afraid my idea might not work, mainly because of the heat it can put out. I'll just have to relocate the alarm keypad panel where I can plug it in normally - thanks for all the help people!
Old 06-13-2011, 06:32 PM   #8
Master Electrician
Rewards Points: 3,916
Are you talking about the keypad or the control panel? No alarm system keypad that I am familiar with requires a transformer.
brric is offline   Reply With Quote
Old 06-13-2011, 09:21 PM   #9
AWK
The control panel I have contains the keypad (keypads by themselves are usually battery powered)
Old 06-13-2011, 10:07 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Arlington Industries
Old 06-13-2011, 10:10 PM   #11
http://www.arlcatalog.com/Fan_Specia...nstruction.htm
Probably not deep enough though for a wall wart.
Old 06-13-2011, 10:17 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
You could make a hole in the wall and install the plug inside it, I don't think this would be against code. The keypad would then cover said hole, or maybe a picture could. In fact I'd just put the keypad and plug in a custom recessed enclosure and have a picture over it. The picture would have hinges and just swing open like a door. Put a fake keypad at the entrance.
Old 06-13-2011, 11:59 PM   #13
Your best bet is to extend the wire to a regular receptacle.
You can add to the wire by splicing some 18 awg wire to it. Fishing that new wire is not terribly hard especially if you do some Googling for instructions.
This would allow you to mount it like we do - direct to the wall - and the wires are in the wall. If you can locate it just above a receptacle, fishing it is easy, otherwise you'll need to do some drilling from the attic or basement if available to get your wire to an available receptacle.
Jim
Security101 is offline   Reply With Quote
Old 06-14-2011, 12:37 AM   #14
AWK
Thank you Speedy Petey for the link - I'll measure and see if it will work. Security101, I think that routing it to a regular plug might end up being my best option. The security system is made by Skylink (SC100), so it's not an elaborate or professionally monitored system, but it provides some security for my condo. Thank you for your recommendation.
Old 06-14-2011, 05:25 AM   #15
Jim
Fishing cord like that is not terribly legal though.
Tags
adapters , electrical , hidden , outlets , plugs
apartment: 3-pronged, ungrounded outlets pro_DIYer Electrical 9 10-15-2008 04:22 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 03:52 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
