Question About Changing A Service Panel (breaker Box) - Electrical - Page 8 - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:16 AM   #106
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
It may be acceptable in your locale, but since you won't tell us what state your are in we can't help. As for dealing with the city, document your correspondence for future use. As for the contractor, again if we knew what state you are on we may be able to offer some guidance.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-27-2013, 10:18 AM   #107
electures's Avatar
Originally Posted by Bradeno
Electures, I hadn't considered extending it. If heat is really a problem in this pipe, how does extending the pipe make the situation any better? That doesn't make sense to me.
Because in addition to extending it you have to run several conduits and limit the number of cables to four each.
Old 02-27-2013, 10:20 AM   #108
Licensed electrician
Rewards Points: 1,456
It doesn't matter if it makes sense. The rules state the sleeve must be at least 18" in order to meet the requirements.
I am sorry that the contractor did not know that this was wrong or why the inspector passed it. The fact remains that both were wrong. As a responsible contractor they should be willing to stand behind their work and make it right.
Old 02-27-2013, 10:28 AM   #109
The house is in WI. I just called the inspector and he said that WI doesn't have any such requirement on the number of cables that can go in the pipe (actually said I could fill it all the way and it wouldn't be a problem) and that the only thing he was really concerned with was access to the raceway.
He assured me there is absolutely no fire hazard here and denied this reading/interpretation of the code.
Bradeno is offline   Reply With Quote
Old 02-27-2013, 10:33 AM   #110
Well again he is showing his ignorance of both real hazards and the NEC that they should be enforcing.
Does WI have any building codes they enforce?
Old 02-27-2013, 10:35 AM   #111
Oh yes, believe me, they do.
And they have no qualms about enforcing them.
So, I have difficulty understanding why he would let this fly if it really weren't ok since he doesn't seem to have any special affinity for me or this project and loves to point out hazards and make lists
Old 02-27-2013, 10:46 AM   #112
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm in WI...SE WI to be exact. Just so you are aware, a master electrician does not have to do the work. A master electrician with the backing of a licensed electrical contractor must pull the permit. Once the permit is pulled, anyone who the EC employs can perform the work. That will somewhat change April 1st of this year. Then, anyone performing electrical work MUST be licensed by the state. There are a number of types of licenses, but everyone must have one.
The reasons are a little unclear, but from what I understand, they are going to eliminate the need for an EC to have a license in every individual community and simply have one license from the state.
If you are in the SE WI area, tell me which community and I can give you an idea of the inspector.
Old 02-27-2013, 10:48 AM   #113
I am not there. It is a city code that requires it to be a Master Electrician. Believe me, I tried this already I hope to have this house finished and on the market and sold (yeah right in this economy) by April 1st.
Old 02-28-2013, 09:21 AM   #114
electures's Avatar
Now you see why we ask for your location. Nobody cares about your address, just your location. K-Buz is local to you and provided you some good info!! PM K-Buz the town and he may be able to help you further.
Keep us posted.
Old 02-28-2013, 09:42 AM   #115
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm trying to find some articles in our professional trade magazines to beef up the advice given here and to give the op some leverage .... here is one from Electrical Contracter Magazine. Last article in the series of questions being answered.
http://www.ecmag.com/section/codes-s...dential-wiring
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-28-2013, 09:48 AM   #116
UAW SKILLED TRADES
Stubbie's Avatar
Here is another with a graphic ...
http://ecmweb.com/qampa/stumped-code-2
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
electures (02-28-2013)
Old 02-28-2013, 10:00 AM   #117
UAW SKILLED TRADES
Stubbie's Avatar
Now that we know where the house is .....
I pulled this from the Wisconsin state site located here ... it is an amendment to 312.5(c)
http://archive.org/stream/gov.wi.ele...rical_djvu.txt
Substitute the following wording for NEC 312.5 (C) Exception
(intro.):
Exception: Cables with entirely nonmetaUic sheaths shall be
permitted to enter an enclosure through one or more nonflexible
raceways of not less than 12 inches and not more than 10 feet in
length, provided all of the following conditions are met:
(2) Omission [nec 312.5 (C) exception]. NEC 312.5 (C) Excep-
tion paragraph (b) does not apply in Wisconsin.
(3) Fitting [NEC 312.5(C) EXCEPTION]. Substitute the following
wording for NEC 312.5 (C) Exception paragraph (c):
A fitting is provided on each end of the raceway to protect the
cable(s) from abrasion.
Stubbie
electures (03-01-2013)
Old 02-28-2013, 10:15 AM   #118
UAW SKILLED TRADES
Stubbie's Avatar
I noticed it removes the requirement for a surface mounted box in the intro paragraph.
Stubbie
Old 02-28-2013, 06:16 PM   #119
So it is basically just fine then based on those changes? An inch on the pvc isnt a hazard just a uniform standard.
Or are there still too many wires in it?
Old 02-28-2013, 11:27 PM   #120
UAW SKILLED TRADES
Stubbie's Avatar
No ... nothing has changed that keeps your installation from being non-compliant. It is still in violation of Wisconsin code. Read the amendment I posted ... you seem to be stuck on this idea that you can make yourself believe it is not in your opinion a hazard so it's ok to leave it.
The inspector passed it so you can move on if you want. If someone told you it isn't a hazard would that change anything as far as the installation being code compliant?
BTW the inspecter IMO is uncertain but sees no hazard so he is passing it. I also think he knows what NEC article to reference by the fact he is requireing access to the sleeve of pvc. Unfortunately he is requireing you to do something that is not required by Wisconsin state code amendments to NEC 312.5(c).
Look I'm done here I don't know what else to provide to help you with this delimma of yours .... jeez engineers drive me nuts......
Stubbie
The Following 3 Users Say Thank You to Stubbie For This Useful Post:
electures (03-01-2013), Jim Port (03-01-2013), Speedy Petey (03-01-2013)
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 04:09 PM
Tandem breaker positions in main service panel elmaur Electrical 14 05-11-2012 01:28 PM
100amp service to 200amp service - double or single panel CapeCod153 Electrical 8 05-09-2012 08:03 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
