Question About Adding Outlets To My Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 03:27 PM   #1
question about adding outlets to my basement
friend of a friend who is electrician says he can add outlets to our basement by coming off of outlets in our kitchen. we have way too many outlets in the kitchen\dining room area, several never get used.
he also is telling me that all of our breakers in our box are 15 amp, and he can replace them with 20 amp, so we can run more things off of them without the breaker tripping like it did last christmas (all the lights and stuff). he says it is unusual that a 5 year old house like ours has all 15 amp.
does that make sense? any downside to going to 20 amp fuse?
jtkirk is offline   Reply With Quote
Old 09-26-2011, 03:31 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
Not much of an electrician.
Kitchen circuits can only be used by the kitchen and dinning room.
Unless all the wire on the circuit is #12, then the breaker can not be changed to a 20 amp.
The kitchen, bathroom, and laundry rooms reguire 20 amp circuits, unless you are located outside the US.
jbfan is online now   Reply With Quote
Old 09-26-2011, 03:43 PM   #3
he is supposed to be checking on the wiring. the basement currently has 15 amp.
we have 5 outlets in our dining room area, only use 2 ir 3 (dining room is 20 amp and is on separate breaker from kitchen), any problem with using couple from the dining room in the basement?
Old 09-26-2011, 03:48 PM   #4
jbfan's Avatar
Rewards Points: 482
Yes.
Kitchen and dinning room receptacles can only serve the kitchen and dinning room.
Old 09-26-2011, 03:51 PM   #5
is it against code, or just frowned upon?
Old 09-26-2011, 03:53 PM   #6
jbfan's Avatar
Rewards Points: 482
Against code.
Old 09-26-2011, 04:32 PM   #7
oy vey
Old 09-26-2011, 05:05 PM   #8
Rewards Points: 150
Article 210.52(B)(2)
No other outlets
The two or more small appliance branch circuits specified in 210.52(B)(1) shall have no other outlets
Sunny B. is offline   Reply With Quote
Old 09-26-2011, 05:13 PM   #9
now, just to be clear, the dining room is on different breaker from the kitchen.
but I understand you to say that 210.52(B)(1) still applies to the dining room area even then, correct?
sorry if I ask dumb questions or repeat them, I am a PC guy, thats all I know, nothing about wiring houses.
Old 09-26-2011, 05:17 PM   #10
Rewards Points: 150
That's the way it's suppose to be. You should have 2 separate circuits for the kitchen, and 2 separate circuits for the dining room
Old 09-26-2011, 05:18 PM   #11
Rewards Points: 150
"Small appliance circuits" that is
Old 09-26-2011, 07:16 PM   #12
Licensed electrician
Rewards Points: 1,622
Almost, both of the 20 amp small appliance circuits do not need to serve the dining room. The requirement is for the dining receptacles to be served by one of the SABC. You could do both circuits or you could add a third SABC.
Old 09-26-2011, 09:37 PM   #13
kbsparky's Avatar
In any case, the dining room circuit for receptacle outlets can not be connected to any basement outlets.
Your friend of a friend needs to find another hobby ...
-KB
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 10:19 AM
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 06:15 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Adding Circuit for basement remodel ksl Electrical 3 01-10-2011 08:58 PM
finishing basement question fabian Building & Construction 6 06-19-2009 11:59 AM
