Old 07-20-2007, 11:23 PM   #1
Question on 240v to ac(window unit)
I just replaced a window unit with a newer one. The new unit requires 30a-240v. I have a little experience wiring regular 3 wire B/W/G or bare. This new outlet and unit came with some instructions. It calls for 4 wires but i only see connections for three wires on the outlet...here's the exact instructions:
"Connect green(ground) wire to green terminal and white(neutral) to silver terminal. Connect black and red(hot) one to each remaining terminal."
The problem is there are only 3 terminals on the outlet. My dad (who has a little more experience them me) says to connect the ground to green screw and the hot (red and black) to the other two screws. Is this correct and what about the neutral?
evosounds is offline   Reply With Quote
Old 07-21-2007, 12:31 AM   #2
" Euro " electrician
frenchelectrican's Avatar
If your instruction secifely say 4 wire then you have to run new 10-3/G romax wire because some of new A/C do required netutral for control system but just cirous what brand name the unit you got ??
maybe i can find a way around but need to know what brand that unit is so i can search the info
Merci , Marc
Old 07-21-2007, 12:45 AM   #3
it's a frigidaire unit 18000 btu. heat and cool.
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
240v Question scoot_gt Electrical 5 07-18-2007 10:32 AM
A/c unit question bgd73 HVAC 1 07-04-2007 01:09 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
