-   -   Question on 240v to ac(window unit) (http://www.diychatroom.com/f18/question-240v-ac-window-unit-10042/)
evosounds 07-20-2007 10:23 PM
I just replaced a window unit with a newer one. The new unit requires 30a-240v. I have a little experience wiring regular 3 wire B/W/G or bare. This new outlet and unit came with some instructions. It calls for 4 wires but i only see connections for three wires on the outlet...here's the exact instructions:
"Connect green(ground) wire to green terminal and white(neutral) to silver terminal. Connect black and red(hot) one to each remaining terminal."
The problem is there are only 3 terminals on the outlet. My dad (who has a little more experience them me) says to connect the ground to green screw and the hot (red and black) to the other two screws. Is this correct and what about the neutral?
frenchelectrican 07-20-2007 11:31 PM
If your instruction secifely say 4 wire then you have to run new 10-3/G romax wire because some of new A/C do required netutral for control system but just cirous what brand name the unit you got ??
maybe i can find a way around but need to know what brand that unit is so i can search the info
Merci , Marc
evosounds 07-20-2007 11:45 PM
it's a frigidaire unit 18000 btu. heat and cool.
