Question ?????? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 04-17-2013, 09:30 PM   #16
biggles's Avatar
skinny guy but if you have the LBs that is resistance as the electric flows you would drop first ..and probably not trip...short piece of wire jumped will trip it,radio into the water blow dryer...stuff like that..
biggles is offline
Old 04-17-2013, 09:34 PM   #17
Rewards Points: 4,796
Originally Posted by mpoulton View Post
I assumed roughly the same resistance hand-to-hand as hand-to-foot. That's an approximation, and actually ignores skin resistance which is more significant than body tissue resistance. The contact point resistance at each hand will be much higher than the "contact" resistance between the feet and the water. In reality, I would expect more current to exit the feet than the neutral hand, assuming the tub water is grounded and the water is conductive.
The water itself might be non-conductive if it's very pure, but that's not likely. Tap water is plenty conductive enough, although not as conductive as the inside of a person.
I got you, we're on the same page.
I guess I don't understand why they're saying the GFCI circuit wouldn't trip then.
jeffnc is offline
Old 04-17-2013, 09:45 PM   #18
r0ckstarr's Avatar
Rewards Points: 2,012
Great thread. I now have a better understanding of GFCI's.
r0ckstarr is online now
Old 04-18-2013, 12:01 AM   #19
" Euro " electrician
frenchelectrican's Avatar
I don't really know what you mean by that. I assumed roughly the same resistance hand-to-hand as hand-to-foot. That's an approximation, and actually ignores skin resistance which is more significant than body tissue resistance. The contact point resistance at each hand will be much higher than the "contact" resistance between the feet and the water. In reality, I would expect more current to exit the feet than the neutral hand, assuming the tub water is grounded and the water is conductive.
The key issue is with super pure water it will NOT conduct any electricty at all but once you put inpures like salt then it will really increase the chance of getting conducted ( hook up in some way )
C'est simple ., If the supply conductor and return conductor ( line and netural ) going thru the GFCI or RCD and read balanced it will not trip but once it get unbalanced it will trip them.
Just take a jumprope ( for a simple demo ) fold it in half and pull it tight and you should see equal length and tenison that the same idea with RCD or GFCI will not trip., Now have a person or something hang it on one side of the rope it don't matter which side and see how the rope twist then it become unblanced which it will trip the RCD or GFCI due the person or something hanging on the rope and force it off balanced.
That is kinda rough example but I hope other members may have better idea what it is.
Merci,
Marc
frenchelectrican is offline
Old 04-18-2013, 05:24 AM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Hopefully they'd understand the principles of how electricity flows, which is what this question is mostly about.
My point is most electrical engineering and construction electrical are two VERY different things.
So you are saying no electricity would flow through the water? Why not?
When did I say that?
But to answer, no. Some current would flow but not nearly enough to trip a breaker. Even dirty water is not conductive enough to cause a short or even simply trip a breaker.
Most people have a drastic misconception of the whole water/electricity relationship.
I do think there would eventually be enough fault current to trip the GFI. Although in this pretty much impossible scenario it's hard to tell.
Speedy Petey is offline
Old 04-18-2013, 06:51 AM   #21
Master Electrician
Rewards Points: 3,824
Some posters are not differentiating between a breaker tripping versus a GFCI tripping.
brric is offline
Old 04-18-2013, 07:39 AM   #22
I understand the principle. Maybe some actual numbers will help. I guess I'm surprised that people are saying only a tiny amount of electricity will flow through the water in this example. My guess is that it would be enough to trip the GFCI, but you guys are saying no, so....
jeffnc is offline
Old 04-18-2013, 08:00 AM   #23
Roofmaster
Rewards Points: 2,172
Nothing, as long as you wear a hat.
jagans is offline
Old 04-18-2013, 10:19 AM   #24
Rewards Points: 130
Originally Posted by Philly Master View Post
here is a question ... FUN one ..
your standing in a bathtub full of water.... naked ... you put your right hand "IN" the neutral side of the GFI ...and your Left hand in the Hot side ( for the DIY ) would the GFI trip ...or would you get electrocuted ??
AND WHY !!!
They should pull your license for posting this stuff on a DIY forum.
If you want to show off go here www.electriciantalk.com
J. V. is offline
Old 04-18-2013, 02:12 PM   #25
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
why ? its educational ..... not showing off ... it was posed in a class i took ... and really helped and brought good discussion ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline
Old 04-18-2013, 02:37 PM   #26
Oso954's Avatar
Rewards Points: 1,022
My question is why is that reversed ?
When you stand in front of a GFCI installed ground pin down, the neutral is on the left and hot is on the right. So, to follow the instructions you would be crossing one hand over the other. Based on the spacing most people would end up with a firm contact at the wrists.
Is that part of a trick question, or just mis-leading information ?
Oso954 is offline
Old 04-18-2013, 04:08 PM   #27
Rewards Points: 516
commercial guys installed the outlet so the ground pin is up ...
Old 04-18-2013, 04:09 PM   #28
JOATMON
ddawg16's Avatar
Rewards Points: 1,458
At least we are not talking about using PVC for airlines....
ddawg16 is offline
The Following User Says Thank You to ddawg16 For This Useful Post:
Philly Master (04-18-2013)
Old 04-18-2013, 05:35 PM   #29
Rewards Points: 20
Lol. Who do you think designs gfci outlets?? What exactly do you think electrical engineers do? This I'd like to hear
Maynard is offline
The Following User Says Thank You to Maynard For This Useful Post:
mpoulton (04-18-2013)
Old 04-18-2013, 05:43 PM   #30
That exactly proves the point that electrical engineers and commercial electricians do two completely different things?
OCPik4chu is offline
Closed Thread
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
