Question ?????? - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 04-17-2013, 06:53 PM   #1
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Question ??????
here is a question ... FUN one ..
your standing in a bathtub full of water.... naked ... you put your right hand "IN" the neutral side of the GFI ...and your Left hand in the Hot side ( for the DIY ) would the GFI trip ...or would you get electrocuted ??
AND WHY !!!
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline
The Following User Says Thank You to Philly Master For This Useful Post:
r0ckstarr (04-17-2013)
Old 04-17-2013, 07:22 PM   #2
Rewards Points: 4,792
I'm not an electrical engineer, but I believe the breaker would trip. The electricity sees far less resistance flowing through your body to the neutral side of the circuit than through your body and then the water, however that should simply mean that less current should flow through the water - but not zero. This of course assumes your plumbing is metal and goes to ground.
Interestingly, if you take the water out of the equation, you get electrocuted (because the GFCI sees you as a normal electrical appliance.) So in this case standing in water is safer than not! An apparent paradox, but that is how GFCI is meant to work.
Good question.
(The above is my guess at a hypothetical question, not the definitive answer, in case some idiot at home wants to try this.)
jeffnc is offline
The Following User Says Thank You to jeffnc For This Useful Post:
Philly Master (04-17-2013)
Old 04-17-2013, 07:24 PM   #3
Rewards Points: 1,442
Depends on how "good" a contact was made at each of the 3 points, fingers on receptacle slot contacts (2 places), and feet through water to metal drain fitting to plumbing system to gounding electrode conductor back to panel..
Some current will flow through your body between hot and neutral, and some current will flow through your body between hot and ground. If the latter is less than a few milliamperes, the ground fault interrupter unit will not trip and you could be electrocuted by the hot to neutral flow.
AllanJ is offline
The Following User Says Thank You to AllanJ For This Useful Post:
Old 04-17-2013, 07:33 PM   #4
Hmm, I like Allan's answer too. Very thought provoking....
jeffnc is offline
Old 04-17-2013, 07:46 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,896
The equivalent circuit for this is approximately three resistors in a wye arrangement. Two of them are your arms going to the receptacle slots, and the third is your body going into the bathtub. If the bathtub is grounded, then two points are at zero potential (right hand and feet) while the third is at 120V (left hand). So the result is that current flows in the left hand, and out both the right hand and the feet. The current out of the right hand would be similar to the current out of the feet (depends on the relative resistances of those body parts). This would trip the GFCI since a substantial amount of the current leaving the hot terminal does not return through the neutral, but instead goes to ground through the bathtub.
If the bathtub is fiberglass with a PVC drain line, the result may be different. The water in the tub is isolated from ground. Now the circuit is just hand-to-hand, and all current returns through the GFCI so it doesn't trip. You get electrocuted, but the bathtub has nothing to do with it.
One thing will definitely not happen: the breaker will not trip. There's no conceivable way that more than 15A will flow in this scenario. That would require a total resistance of 8 ohms or less, but body resistance is on the order of hundreds of ohms even neglecting skin resistance.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now
The Following User Says Thank You to mpoulton For This Useful Post:
Old 04-17-2013, 07:52 PM   #6
I don't understand why you're saying this, since the resistance of water must be more significant than the difference of the resistances of your hand and foot paths.
jeffnc is offline
Old 04-17-2013, 07:54 PM   #7
Rewards Points: 516
bathtub and water is the trick of the question ...LMAO
I was posed in a class and the answer given was no trips and ZIT ZIT ZIT
Old 04-17-2013, 07:55 PM   #8
Rewards Points: 516
body is 90% water ??
Old 04-17-2013, 07:57 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
Allan pretty much covered the points....
The kicker is that if your bathtub is a newer fiberglass tub with all ABS drains....chances are nothing will happen if you touch just the neutral or hot....the tub is effectively 'floating' (voltage wise), hence, no path to ground. In fact, you could be in the tub....drop a hot wire into the tub....and as long as you don't touch anything outside of it....your fine....
Now...when you touch both the hot and neut.....your a$$ is getting zapped....and I doubt the breaker will trip....should wake you up....
ddawg16 is offline
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 04-17-2013, 08:23 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
What does being an EE have to do with it??? I'd bet most EE's don't even know the principle of how a GFI works.
And no, the breaker would NOT trip. Not for a while at least.
Speedy Petey is offline
Old 04-17-2013, 09:56 PM   #11
Hopefully they'd understand the principles of how electricity flows, which is what this question is mostly about.
So you are saying no electricity would flow through the water? Why not?
jeffnc is offline
Old 04-17-2013, 09:58 PM   #12
Again, the difference between your hand and foot paths is going to be very small. The resistance of water is going to be much higher than the amount of that difference.
jeffnc is offline
Old 04-17-2013, 10:00 PM   #13
But you said "and why?" So why is it that no electricity would flow through the water?
jeffnc is offline
Old 04-17-2013, 10:04 PM   #14
I don't really know what you mean by that. I assumed roughly the same resistance hand-to-hand as hand-to-foot. That's an approximation, and actually ignores skin resistance which is more significant than body tissue resistance. The contact point resistance at each hand will be much higher than the "contact" resistance between the feet and the water. In reality, I would expect more current to exit the feet than the neutral hand, assuming the tub water is grounded and the water is conductive.
The water itself might be non-conductive if it's very pure, but that's not likely. Tap water is plenty conductive enough, although not as conductive as the inside of a person.
Old 04-17-2013, 10:11 PM   #15
JOATMON
ddawg16's Avatar
Electricity needs a path to flow.....
If the bathtub is fiberglass with all plastic plumbing....there is not electrical path to ground.
Ever see the guys who do the power line maint? Helicopter deposits them on the power line and the scoot down it without an issue....even though they are sitting at over 100K volts....no path between their body and ground.
As for tripping the breaker....while your body typically has a lower resistance than water....the amount of current flow is dependent on several factors...if the bathtub is 'floating' (not grounded)....you can touch either conductor but no current will flow. But, if you touch both of them...current will flow through your body.
It does not take much current for you to die....once again, several factors...your health...surface area of the contact between your fingers and the conductors, how much salt is in your body and on your skin...etc. But that current is really no where near the breaker trip point....so, grab both conductors with both hands and enjoy the ride....
Side note....grab both those wires with the same hand....it's going to hurt...could burn your fingers....but it's not going to kill you....not going through your heart....and it still won't trip the breaker...
ddawg16 is offline
Closed Thread
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
