Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 11:19 AM   #1
Rewards Points: 326
Question
Hello
On my panel board that houses my circuit breaker, there is a power outlet connected to the circuit breaker (of course) about 1/2 ft away. There is no other connection going out of that said power outlet.
Could i run an additionally power outlet or lightbox off that same power outlet, or is there a code against it? meaning that it should be the only thing?
i can run the line, just curious to know if that one power outlet should be isolated?
Amitabh is offline   Reply With Quote
Old 03-09-2013, 11:35 AM   #2
Rewards Points: 82
Some electricians will install a receptacle next to the panel. We must be on the same page if we are to answer your question.
Is this a receptacle like the other receptacles around your house?
"On my panel board that houses my circuit breaker"
What does this mean? Panel that houses multiple circuit breakers, or panel that houses one (your) circuit breaker? Answer this question before anyone can help you.
If the panel is a load center with breakers and not a disconnect with one breaker, you can add more receptacles to this circuit.
If this panel only has one breaker in it, and it is a disconnect for something else, you cannot use it.
Old 03-09-2013, 11:36 AM   #3
MarginallyQualified
Rewards Points: 2,464
Basement? Code requires at least one outlet.
Installing that close to the panel costs less.
Could i run an additionally power outlet or light box off that same power outlet
You sure could. I'd suggest using it ONLY for receptacles though.
Assuming this is in a basement.... there should be some lighting down there already. Use THAT circuit for any additional lighting.
Old 03-09-2013, 12:15 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If the receptacle is a legal connection to a circuit breaker in a loadcenter (as J.V. is trying to clarify) then it would be perfectly legal to extend to lighting or receptacles from that branch circuit. Keep in mind you may have to gfci protect the receptacles to be compliant with current codes.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
J. V. (03-10-2013)
Old 03-09-2013, 03:02 PM   #5
Rewards Points: 326
Hello Everyone
Thank you for the quick responses. I should have attached a picture to clarify what i was trying to speak too.
As you can see there is an orange extension cord. I want to remove the use of the orange extension cord and simple run a proper electrical wire to the place that i want power to be and in between a lamp.
Yes this is the basement.
I could run the new power outlet and lamp off an existing lamp in the basement, however, the electrical wire will go up into my breakfast table to power our small appliances. Right now, that orange extension you see runs up all the way into the kitchen.
Amit
Old 03-09-2013, 04:34 PM   #6
Although I'm not sure of the code in you're area, as long as its done correctly you can absolutely run another plug off that with some 14-2 wire. Splice together the old wire with the new one(black-black, white to white and ground -ground) as well as a short piece of each wire which is called a tail that you'll use to connect back onto your original outlet
Bubski27 is offline   Reply With Quote
Old 03-09-2013, 05:01 PM   #7
MarginallyQualified
That receptacle has a defined purpose.
Do not add to it... leave it be.
Fix that. Whatever the kitchen may need and any other work you may be thinking about (ie what your OP asks)... should be done with new circuits.
Old 03-09-2013, 05:04 PM   #8
Rewards Points: 326
So leave it only! So, curious, what is its purpose?
ok, so i have two options, connect something new to the circuit breaker or find a power source from another source.
Old 03-09-2013, 08:08 PM   #9
TTW
TTW's Avatar
Just install a new circuit breaker, you have lots of room in the panel. A GFCI breaker would be a good idea for the kitchen...
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 03-10-2013, 01:26 AM   #10
Rewards Points: 83
In our area that we are supposed to have a receptacle 6" from the panel on a dedicated circuit. GFI if wet location. If you add to it its not dedicated any more.
find a nearby receptacle in the kitchen and fish up to the junction box from the basement and pull a #12 from there to your new receptacle location.
mech_gui is offline   Reply With Quote
Old 03-10-2013, 01:29 AM   #11
Rewards Points: 83
It is in the event there is catastrophic failures in the house and electrician can turn the power on to just that receptacle to run power tools to fix any hazards.
so I am told...
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
