#1 |
Question
I want to have outlets on the same stud located at 48" and 15" off the floor on seperate circuits.
Can I run the lower outlet romex behind or around the upper outlet box or does it need to enter the upper box/wire nut/exit the upper box to the lower outlet? |
#2 |
Electrical Contractor
Question
If you run the wire behind the box, you will not meet the min. distance from the edge.
What I do is bring the wire down the other side of the stud, then drill and bring my wire back to the box.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Question
JB, I think he wants to know if he can run a different circuit through (spliced) the upper box. This is interesting because if different circuits (on different breakers) are ran and spliced through the same circuit boxes, turning off one breaker doesn't insure that a box is dead. I hope I'm describing this right.
#4 |
Licensed electrician
Question
Just go around the side of the box that is not being used for that circuit.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#5 |
Question
Deleted post.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. Last edited by rrolleston; 06-12-2012 at 03:21 PM. |
#6 | |
QuestionQuote:
Reason I want this odd structure is the lower box is a dedicated circuit for my equipment rack and the upper box is a dedicated circuit for my projector The upper box will serve as a PowerBridge to the projector and plugged into a UPS http://www.amazon.com/PowerBridge-SS...ds=powerbridge To be more clear, the projector will be on a UPS that will also have a few other items on them. The lower outlet on its own circuit will be for mainly receivers and amps Last edited by LarryM; 06-12-2012 at 03:50 PM. |
#7 | |
QuestionQuote:
I'll see if I can do that, I have the return vent from the HVAC running down that wall so it is pretty tight right now. |
#8 |
Question |
#9 |
Question
Is 2 circuits into 1 box against NEC?
Also what is securement rules? I have been placing staples or stackers every 18" on vertical runs and staples about 36" on horizontal runs. |
#10 |
Average Joe/ex-Navy IC3
Question
When looking at the stud cavity, if the lower box is on lets say the left side of the stud bay, run the other wire on the right side, or vice-versa. Not rocket science. Done all of the time. Or, just place the higher box on the right or left side of the stud, lower box on the opposite. Staple according to the inside face inside the stud bay. Again, not rocket science.
As for those powerbridge outlets, personally they are junk, and not worth the money. You can still run the dedicated circuits into a panel that is protected by a battery backup system, that uses deep cycle batteries, and uses the same technology as a standard UPS. Plus the bb system is a lot more hardier and will last longer than most junk ups out there.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#11 |
Question
The NEC only requires the cables to be stapled at intervals of no more than 4 1/2' and within 8 of a box without a clamp or 12" if the box has a clamp of the box they connect to.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. Last edited by Jim Port; 06-13-2012 at 08:00 AM. |
#12 | |
E2 Electrician
QuestionQuote:
#13 | |
QuestionQuote:
Thanks |
#14 |
Question
Sorry, I just use a nice sweep around the other box. No need for 90 degree bends. Something like a staple a foot below and a foot above the other box.
| The Following User Says Thank You to Jim Port For This Useful Post: | Code05 (06-12-2012) |
#15 | |
QuestionQuote:
| Display Modes | |
| DRIcore question | trailblazer1229 | Flooring | 0 | 02-24-2010 10:25 AM |
| 3 Phase meter socket question | a320200 | Electrical | 4 | 12-11-2009 01:45 AM |
| An unasked question is the only dumb question | jackie treehorn | Kitchen & Bath Remodeling | 1 | 09-20-2009 09:24 PM |
| A question about water preassure. | reasonforseason | Plumbing | 5 | 04-14-2009 05:36 PM |
| Basement Renovation Question | KUIPORNG | Remodeling | 234 | 08-26-2008 09:19 AM |
