Question: 14 On 20 AMP With One Foot Run. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 11:09 AM   #1
Question
Question: 14 on 20 AMP with one foot run.
Here is the Issue: I installed an outlet in a closet on the opposite side of the wall of an existing outlet. And wired it with 14. This run is around a foot. The outlet I ran it from has an 15 AMP outlet but the wire feeding it is 12 and is on a 20 AMP breaker. I didn't notice this until I was done wiring it. Is this unsafe should I bother rewiring it? Someone already told me that on this short of run it doesn't matter.
JonoPorter is offline   Reply With Quote
Old 06-10-2011, 11:13 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Redo it with the correct wire.
Old 06-10-2011, 12:07 PM   #3
Rewards Points: 1,016
ditto
Old 06-10-2011, 12:13 PM   #4
Licensed electrician
Rewards Points: 1,780
Or change the breaker to a 15 amp and lose 25% of the circuit capacity.
Old 06-10-2011, 04:08 PM   #5
Learning by Doing
Leah Frances's Avatar
Re-wire it or swap the breaker to 15amp.
And don't take electrical advice from 'someone'. He doesn't know what he's talking about or he's cavalier.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-10-2011, 10:18 PM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Change the wire to 12 wire. The circuit may be a small appliance branch circuit which requires a 20A breaker.
electures is offline   Reply With Quote
Old 06-10-2011, 10:35 PM   #7
I ask the impossible!
Rewards Points: 704
Just to be clear about the part you asked about but which nobody else actually adressed directly... The 15 amp receptacle is allowable on a 20 amp circuit.
20 amp circuit can not have 14 ga. wire.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-10-2011, 10:37 PM   #8
electures's Avatar
Yes and yes.
Old 06-10-2011, 11:09 PM   #9
Rewards Points: 6,652
There is that catch 22 about lighting, that the manufacturer uses smaller gauge wire on the fixture.
Old 06-10-2011, 11:28 PM   #10
electures's Avatar
Lighting does not belong on a small appliance circuit. Assuming it is in fact a small appliance circuit.
Old 06-10-2011, 11:36 PM   #11
Nothing was stated by the OP that this may be a Small Appliance Branch Circuit. I am assuming that it is not, because nothing was stated that this circuit is in the Kitchen or Dining areas. For all we know, it could be in the garage, basement, who knows where. Just to clue you in, it was stated that this circuit feeds a closet, which means that it is a lighting circuit, which can feed off of a receptacle circuit in the Living Room, Basement, bedrooms, Garage, who knows, only the person doing it knows what it feeds off of.
Old 06-11-2011, 12:46 AM   #12
" Euro " electrician
frenchelectrican's Avatar
Yes and yes.
common 15 amp duplex receptales are allowed on 20 amp circuit {unless stated in your local code otherwise }
But Singleplex 15A receptale then no it is not legit on 20 amp circuit.
That part I just want to clear it up before someone jump on this one too quick.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
gregzoll (06-11-2011)
Old 06-11-2011, 06:16 AM   #13
Rewards Points: 1,540
The tap rule (I forget chapter and verse in the NEC) allows the little (16-18 gauge) wires, called taps, in a light fixture to connect to a 15 or 20 amp circuit. This rule specifies the maximum length of such smaller wires, it is something like 14 inches, preventing 14 gauge wires from the wall switch all the way up to the ceilint light in a 20 amp circuit.
Now there are bathroom lights with a shaver receptacle (labeled max X watts) that have <14 gauge wires to connect to the power source. Perhaps something like this gave someone the idea that running a foot of 14 gauge on a 20 amp circuit was okay. Except that if run to a duplex receptacle, there could be two things plugged in drawing a total of more than 15 amps.
You can have single (non-duplex) 15 amp receptacles on a 20 amp circuit provided there are at least two receptacles altogether.
Heating of the wire due to larger current draw produces just as many BTU of heat at any spot in a 1 foot segment as in a 10 yard segment. It is the spot BTU, not the BTU over the leng6th of the entire wire, that presents a hazard.
OT: Meanwhile the voltage drop in each foot of a piece of wire, with a given load in amperes, is the same. It is the cumulative voltage drop over the entire length of the wire (round trip; hot and neutral for 120 volt circuits) that you are interested in.
AllanJ is online now   Reply With Quote
Old 06-11-2011, 08:32 AM   #14
Electrician
SD515's Avatar
Rewards Points: 504
When someone says “The outlet I ran it from has an 15 AMP outlet but the wire feeding it is 12 and is on a 20 AMP breaker” the first thing that comes to mind is kitchen SABC, laundry or bath receptacles, none of which are allowed to be ‘tapped’ to feed ‘an outlet in a closet’ (in general). Anyone else catch that?
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
electures (06-11-2011)
Old 06-11-2011, 08:39 AM   #15
I think everyone picked up on the incorrect mixing of the wire sizes and may not have thought about the source of the circuit or its possible restrictions.
Pre slope question on shower floor - did I do it wrong? maestro300 Flooring 2 02-20-2009 02:44 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Garage Framing Question wrldruler Building & Construction 5 08-22-2008 08:26 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Site work question Jonny Homefixer Building & Construction 6 11-02-2006 08:43 AM
