...that Is The Question... - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 01:58 PM   #1
Caution! Girl working
...that is the question...
Hello
I recently replaced the prior homeowner's 80-gal. stone lined electric water heater with a 40-gal modern one. I mentioned how excited I was to see a drop in my electric bill and the installers said I'd save more money if I turned the water heater off at the breaker box until about an hour before hot water was needed. I live alone and can easily time it so the heater is on for maybe 1.5 hours every two days (water actually stays hot enough for a shower after being off for 24-hours!). Question is, am I damaging the water heater by doing this? It should save oodles of money on electric.
Not sure if this is a plumbing or electrical question, so I'm going to post it on the electrical forum, too.
Thanks!!
ADaniLion is offline   Reply With Quote
Old 08-18-2011, 02:01 PM   #2
Master Electrician
Rewards Points: 3,678
If you're convinced that this is the way to go, get a timer for the WH.
brric is online now   Reply With Quote
Old 08-18-2011, 02:07 PM   #3
Code05's Avatar
Rewards Points: 1,104
Ditto. It was pretty common for awhile.
Code05 is offline   Reply With Quote
Old 08-18-2011, 02:16 PM   #4
The electrical line runs right into the wall, so a timer would require hiring an electrician (not to mention the cost of the timer itself)...spending all that money seems to defeat the purpose lol! I just want to make sure that the water heater isn't being damaged being turned off and on every couple of days.
Old 08-18-2011, 02:27 PM   #5
Master Electrician
The only way to damage it electrically would be to turn it on with no water in it.
Old 08-18-2011, 05:42 PM   #6
I would think it would take more electricity to go from cold water to hot water, than to just maintain temperature. Could be wrong, but i know once i turned off my electric baseboard heating for 2 weeks while i was away in the winter, and i don;t think i saved any money at all. Just a thought...
MitNotrof is offline   Reply With Quote
Old 08-18-2011, 07:20 PM   #7
And you did get any frozen pipes??!!
asfyxation is offline   Reply With Quote
Old 08-18-2011, 07:25 PM   #8
nah it was a mutli unit building so my neighbors gave enough heat to not drop below freezing, but it was still darn cold in there! lol
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
