Quesions On Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2008, 05:29 PM   #1
quesions on wire
I am wondering what the differance is between #4 gauge wire labled THHN and TNWN is. Also wanted to know if it would hurt to run THHN underground in conduit.
Thanks in advance...
whatluck is offline   Reply With Quote
Old 08-13-2008, 05:33 PM   #2
Electrician
The "W" means its rated for WET locations, so to answer your question, yes its a problem to run THHN underground, but most if not all wire is dual rated these days.
chris75 is offline   Reply With Quote
Old 08-14-2008, 09:38 PM   #3
fix it
For the sake of completeness to the post, make sure you are using the right conduit type and the correct size. It should be rigid non-metallic or rigid metal conduit if it's underground. Size will depend on how many wires you are running.
detailedEye is offline   Reply With Quote
Tags
wiring
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
