Qualified Elericians Please!, Quibble Thread - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 10:56 AM   #61
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
LOL .......
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-09-2013, 11:26 AM   #62
Rewards Points: 516
I have had this discussion before and it comes down to terminolgy ..
you can not have AC in the speaker system or it will hum ..
you have DC ....
say a guitar amp ... the string vibrates over a magnet .... cuasing the magnet to induce both neg and pos , = or -, north or south ... going to amp circuit ...causing the magnet in the speaker to move in and out depending on .. neg and pos , = or -, north or south ...x amount of distance producing sound ... and outputs X vdc + or - moving the speaker
no vibration = no sound
Hum = A/C bleeding in ... that nasty 60 hz hum
amps are/have a rectifier bridge in them ...giving DC to the circuitry ..
Yes the ( DC ) osolations are alternating ... but is it A/C Voltage ....LMAO !!
Old 11-10-2013, 02:18 PM   #63
Rewards Points: 664
I use a non-contact tester frequently. In one house I noticed that every time I went upstairs and just put the tester NEAR the outlet boxes it went off. Normally I have to put it in the hot slot to make it beep. I eventually discovered that a prior owner had connected ground wires upstream to a hot brass screw on an outlet. This electrified the ground and the boxes.
crescere is offline   Reply With Quote
Old 11-10-2013, 02:21 PM   #64
PoleCat's Avatar
Rewards Points: 1,646
Originally Posted by beenthere View Post
He probably left after the derailment. But he might come back and let us know what was found out.
I keep coming back because a good train wreck is hard not to look at.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following 2 Users Say Thank You to PoleCat For This Useful Post:
electures (11-10-2013), Know A Little (11-10-2013)
Old 11-10-2013, 02:43 PM   #65
Rewards Points: 24
If Greg's involved, I get out the popcorn, soda and wait for the show.
Dan
djlandkpl is offline   Reply With Quote
The Following 2 Users Say Thank You to djlandkpl For This Useful Post:
electures (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 02:46 PM   #66
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Bwahhh…. at first I thought it was just me.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
electures (11-10-2013), jbfan (11-10-2013)
Old 11-10-2013, 02:58 PM   #67
Rewards Points: 6,652
Excuse me? If I was involved, there would not be a problem, because I know how to properly troubleshoot and wire electrical circuits. You and your girlfriend Stickboy need to go back and sit in the corner, where you both belong.
Old 11-10-2013, 03:03 PM   #68
E2 Electrician
okay, mister ground rods clear a fault…..
Old 11-10-2013, 03:52 PM   #69
Rewards Points: 24
The only reason I haven't blocked your posts is the entertainment value.
You are a post count junkie. You think this is your forum and everything you post is gospel. I have yet to read an apology from you for providing incorrect information or creating confusion.
Someone else said it. You like to hear yourself talk, hence the 1,000 word posts that don't say much.
I'm waiting for you to pull the "I'm being bullied by the sparkies" card.
Dan
electures (11-10-2013), Philly Master (11-10-2013)
Old 11-10-2013, 04:24 PM   #70
An old Tradesmen
Rewards Points: 6,944
This is where these post belong.
Old 11-10-2013, 05:09 PM   #71
Licensed electrician
Rewards Points: 1,506
Maybe as long as it does not involve understanding grounding.
Not jumping in anyone's camp Greg but you were wrong and failed to admit that the others were correct. Resorting to name calling is not the way to deal with it. It is also against the forum rules.
The Following 7 Users Say Thank You to Jim Port For This Useful Post:
busman (11-11-2013), electures (11-10-2013), jbfan (11-10-2013), Know A Little (11-10-2013), Kpack (11-10-2013), kwikfishron (11-10-2013), stickboy1375 (11-10-2013)
Fine thread to Coarse thread??? tlavery Plumbing 11 04-13-2009 08:51 PM
