Qualified Elericians Please!, Quibble Thread - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 06:49 PM   #46
Rewards Points: 6,652
Originally Posted by dmxtothemax View Post
This thread needs to be closed !
+3. It should have been closed around post #20.
Old 11-07-2013, 06:50 PM   #47
Originally Posted by jeffnc View Post
42.
I've been on this forum for years. This pops up enough on the various subfora. It's a known problem.
That always works for me, when the boss asks for the answer to something, I just quote the answer to life and everything.
Old 11-07-2013, 07:00 PM   #48
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What a strange thread……
The Following User Says Thank You to stickboy1375 For This Useful Post:
Kyle_in_rure (11-08-2013)
Old 11-07-2013, 07:16 PM   #49
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
LOL ....made me think ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
oh'mike (11-08-2013)
Old 11-07-2013, 07:18 PM   #50
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by k_buz
It was a handy man working on an apartment building. It could have been anything.
And since he hasn't returned. I'm done with this thread.
Close it.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-07-2013, 07:19 PM   #51
Rewards Points: 516
someone has been pruning ......
Old 11-07-2013, 07:21 PM   #52
electures's Avatar
Here we go again.
Old 11-07-2013, 07:23 PM   #53
An old Tradesmen
Rewards Points: 6,116
Quibble in this thread. Not the original thread. Any post being make in the original thread should be directed toward the OP.
I thank all of you for your cooperation in this.
The Following User Says Thank You to beenthere For This Useful Post:
gregzoll (11-07-2013)
Old 11-07-2013, 07:28 PM   #54
electures's Avatar
Originally Posted by beenthere
Quibble in this thread. not the original thread. Any post being make in the original thread should be directed toward the OP. I thank all of you for your cooperation in this.
Cool.
Old 11-07-2013, 10:21 PM   #55
Rewards Points: 774
Originally Posted by busman View Post
Other than that, this could be a difficult problem to diagnose over the internet. I'm going out on a limb and guess that this service does not have a proper grounding electrode system and that the neutral has been compromised. Again, voltage readings would help.
Mark
A proper grounding electrode system has nothing to do with this, PROPER BONDING yes, the Earth could care less in this case.
Know A Little is offline   Reply With Quote
The Following 2 Users Say Thank You to Know A Little For This Useful Post:
itsnotrequired (11-07-2013), stickboy1375 (11-08-2013)
Old 11-07-2013, 10:26 PM   #56
Rewards Points: 774
Originally Posted by gregzoll View Post
Throw away your non-contact tester. Give you a clue about how those things work. They work off of the magnetic field created, when current is flowing through a circuit. Most of them are just junk, and tend to either give off false alerts, or pick up there is voltage present, because there is either another circuit in that box, or running next to it somewhere.
Also if this is an apartment, that means rental. If it is a rental unit, you do not hold a license to work on electrical work, I would just call the owner and let them deal with any problems.
Or get a Tic Tracer, We live buy ours for low voltage and medium voltage work
http://www.alliedelec.com/search/pro...ic%20300%20Pro
Even then for trouble shooting LV work it is a Wiggy style or DMM
The Following User Says Thank You to Know A Little For This Useful Post:
Philly Master (11-09-2013)
Old 11-08-2013, 11:10 AM   #57
Rewards Points: 334
Originally Posted by brric View Post
Ring voltage is 90-100 volts AC.
i learnt the hard way too with phones, leave them off of the hook so they can't ring. now all ya have to do is unplug the r2j911 i belive it's called.
circuitman is online now   Reply With Quote
Old 11-09-2013, 06:19 AM   #58
Rewards Points: 516
how about alternating DC .....or DC with hertz ...
ie a speaker ....
Old 11-09-2013, 11:04 AM   #59
JOATMON
ddawg16's Avatar
Rewards Points: 824
ie a speaker ....
LOL.....
Actually, you could say AC is DC......if you have a fast voltmeter and measured the voltage at a specific point....it would be DC.....
For the record.....speakers are AC....with a typical freq of 10hz to 20khz (if you have a really good set of speakers). Just don't expect to see 15Khz out of that sub woofer....
ddawg16 is online now   Reply With Quote
Old 11-09-2013, 11:51 AM   #60
Rewards Points: 516
Fine thread to Coarse thread??? tlavery Plumbing 11 04-13-2009 09:51 PM
