Qualified Electricians Please! - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 06:07 PM   #31
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by electures View Post
After re reading the OP's earlier post, I'm wondering if he did in fact combine the two appliances and this new problem is the result. Since he hasn't responded I guess we will never know.
It was a handy man working on an apartment building. It could have been anything.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (11-07-2013)
Old 11-07-2013, 06:25 PM   #32
An old Tradesmen
Rewards Points: 6,860
Yes, this thread is being moderated.
Old 11-07-2013, 06:35 PM   #33
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The more I think about it the more I am convinced that "someone" connected a dryer into a range circuit somewhere in the complex and it is back feeding the ground. Could be from a different unit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Philly Master (11-07-2013)
Old 11-07-2013, 06:41 PM   #34
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I'm not sure I see where you are going with that scenario? The OP would have to have an open neutral, in any case, i'm not losing any sleep over this one, if I'm not there taking the meter readings myself, and doing the trouble shooting, this type of question is simply impossible to answer.
Old 11-07-2013, 06:52 PM   #35
electures's Avatar
In an earlier thread started by the same op he ask ed about connecting a dryer to a range circuit. Sounds like he did and it is back feeding the ground. Just my thoughts. I'm done with this one also.
Old 11-07-2013, 08:13 PM   #36
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Just as an FYI.....
A typical hardwired traditional phone line is going to have 48 volts DC on it. It's used to determine On/Off hook.
And....if you decide that you want to touch those wires while the phone is ringing....be ready to hold on....
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
gregzoll (11-07-2013), stickboy1375 (11-07-2013)
Old 11-08-2013, 12:39 AM   #37
Rewards Points: 358
Originally Posted by ddawg16 View Post
Just as an FYI.....
when it rings is ac or dc?
circuitman is online now   Reply With Quote
Old 11-08-2013, 07:04 AM   #38
Master Electrician
Rewards Points: 3,810
Ring voltage is 90-100 volts AC.
brric is online now   Reply With Quote
Old 11-08-2013, 07:11 AM   #39
JOATMON
ddawg16's Avatar
At 20 hz......
Feels real good.....
Old 11-08-2013, 07:36 AM   #40
Master Electrician
At 20 hz......
Didn't know the frequency, thanks.
Old 11-08-2013, 08:29 AM   #41
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
After reading the other thread, I think it could be a related issue also.
jbfan is online now   Reply With Quote
Old 11-09-2013, 11:18 PM   #42
dmxtothemax's Avatar
Rewards Points: 5,166
Is the O / P still around ?
Otherwise we are just shooting the breeze !
dmxtothemax is offline   Reply With Quote
Old 11-10-2013, 07:15 AM   #43
An old Tradesmen
He probably left after the derailment. But he might come back and let us know what was found out.
The Following User Says Thank You to beenthere For This Useful Post:
Philly Master (11-10-2013)
Help :) electricians moved insulation ober76 Insulation 16 10-10-2011 10:28 PM
Advice needed on Electricians Tafe course? Daveb2311 Off Topic 3 08-01-2010 08:07 AM
Electricians choice? Thurman Electrical 6 09-21-2009 05:04 PM
Any electricians (espicially from PA)? I have a very quick question... sofakng Electrical 8 04-01-2009 02:47 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 12:38 PM
