Qualified Electricians Please! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 07:03 PM   #16
dmxtothemax's Avatar
Rewards Points: 5,352
Originally Posted by dmxtothemax View Post
Some times the cause can be in a neighbours instalation.
Worth thinking about !
dmxtothemax is offline   Reply With Quote
Old 11-07-2013, 04:26 AM   #17
Do we know for sure that it is fully live ? Has it been tested with a proper tool ? Or is it just ghost voltage, there's been a lot of talk but not much progress with the original problem.
Old 11-07-2013, 04:30 AM   #18
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
IMHO .... this is not ( sorry but ) ...... "GHOST VOLTAGE" if your getting lit up !!!
the "tic" tester works fine for me in residential settings ... and does what it is designed to do .. and in this case ("the OP's post" ) was absolutly correct !!
so there is CURRENT flowing in the ground .....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-07-2013, 04:40 AM   #19
Then its incorrect wiring, or a missing/faulty neutral !
The Following 2 Users Say Thank You to dmxtothemax For This Useful Post:
gregzoll (11-07-2013), Philly Master (11-07-2013)
Old 11-07-2013, 04:43 AM   #20
Rewards Points: 516
LOL those are high level diagnostic words my down under brother ....
Old 11-07-2013, 09:39 AM   #21
Rewards Points: 528
Why not turn off the entire power from the main or have company disconnect(also have them check their end) ,an do the simple ohms test from the appliance incoming to the breaker wire, on each wire and also on neutral to ground,neutral to hot,ground to hot,etc?
Tracing the circuit from breaker out to end of run.
hidden1 is offline   Reply With Quote
The Following User Says Thank You to hidden1 For This Useful Post:
Old 11-07-2013, 12:18 PM   #22
Licensed electrician
Rewards Points: 1,622
The conductor does not have to be hot or live in order to shock someone. It could just be at a different potential compared to the other surface.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
jbfan (11-07-2013), Philly Master (11-07-2013), stickboy1375 (11-07-2013)
Old 11-07-2013, 12:21 PM   #23
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,160
Sorry, I'm not qualified but I do know the phone line still has current when all breakers are off.
Just a thought, don't flame me.
Could phone line voltage travel through plumbing ground to the ground wire of the electrical system if something was fudged with the phone system?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Old 11-07-2013, 01:02 PM   #24
Rewards Points: 6,652
No, because there is no physical path between the telephone circuit and the ground for Lightning protection, unless you have that 1 in a million chance, that you got a short between Ring & Ground, then you would see the problems on the phone line.
There have been cases, where the outer shield on coax for catv has become electrified, and feeds into the ground connection at the static discharge block, but when you trace it out, you find that there is a bad neutral somewhere, not necessarily at that structure, but another, due to the techs have tied all ground wires that are attached to the coax lines, are allowing it.
The Following User Says Thank You to gregzoll For This Useful Post:
123pugsy (11-07-2013)
Old 11-07-2013, 01:26 PM   #25
Master Electrician
Rewards Points: 3,870
Telephone systems are intentionally connected to the grounding electrode, at least in my neck of the woods, as well as cable and satellite installations. It is an NEC requirement.
brric is offline   Reply With Quote
Old 11-07-2013, 01:52 PM   #26
Because of static discharge. The physical inside conductor of the coax and the Tip & Ring do not touch the ground. It is spelled out in Chapter 800 of the NEC, why you are required to have a/v & com connections grounded at the structure. It has nothing to do with just because, it all has to do with bringing that potential down to where you do not have the chance, for the circuit to become electrified if a powered line drops on it, or you have a nearby lightning strike, or static discharge in the air, that would cause voltage to feed on through the line, to the equipment inside the structure.
Majority of the equipment that gets fried during a storm, or electrical problem at the structure, can be traced to poor or no grounding at the entrance for the incoming Coax for Satellite, CATV, Antenna, or Telephone. This is of course for a different topic, not this one.
Old 11-07-2013, 02:07 PM   #27
Rewards Points: 516
the "ground Rod" copper ( lightning protection ) and the Neutrals ARE connected .... as per NEC CODE ....
The Following User Says Thank You to Philly Master For This Useful Post:
brric (11-07-2013)
Old 11-07-2013, 02:48 PM   #28
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Two things to point out
1. When was the last time the op responded to the questions some of our professionals asked?
2. Arguing with some of our non-professionals is like wrestling with a pig in mud. Sooner or later you realize the pig enjoys it.
PS. Mods please please please do not close this thread.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 2 Users Say Thank You to electures For This Useful Post:
gregzoll (11-07-2013), jbfan (11-07-2013)
Old 11-07-2013, 05:57 PM   #29
electures's Avatar
Originally Posted by Philly Master
Yes you did .... now post #40 ...i never comment in that thread ...but since i have experience as an ADMIN on several Vbulletin Forums i do know how to look things up and put 2 and 2 together .....( paint my own picture ) and i realy was only commenting on the 1st post which is the same OP and I would say same building ..IMHO the OP posted this ...need help w/ my dryer hookup in it he said: "Im tryin to wire my dryer into my stove circuit, it has a 3 prong pigtail. The building is old and the power source only has 2 hot wires and a ground, no neutral" so in the old days there was no nuetrals they just used the bare ground wire in the 240 set-ups ... many stoves and dryers DID USE 120 volt for the controls .. SOOOoooo the Ground wire would carry current ... and then at the panel the grounds and the neutrals are all hooked up together .... based on that and experience with older buildings ....blah blah blah ...
After re reading the OP's earlier post, I'm wondering if he did in fact combine the two appliances and this new problem is the result. Since he hasn't responded I guess we will never know.
Old 11-07-2013, 06:01 PM   #30
Rewards Points: 516
yea and he may have not turned off the 2 pole breakers ....blah blah blah ...
Help :) electricians moved insulation ober76 Insulation 16 10-10-2011 10:28 PM
Advice needed on Electricians Tafe course? Daveb2311 Off Topic 3 08-01-2010 08:07 AM
Electricians choice? Thurman Electrical 6 09-21-2009 05:04 PM
Any electricians (espicially from PA)? I have a very quick question... sofakng Electrical 8 04-01-2009 02:47 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 12:38 PM
