Qualified Electricians Please! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 09:00 PM   #1
qualified electricians please!
I have a garbage disposal on a 20 amp circuit and and a dishwasher on a seperate 20 amp. The ground is hot on both at the outlet for the disposal and ata the dishwasher ...any suggestions? 25 year old apartment complex, Im the maintenance guy so yes its legal for me to work on it.
benjammin5150 is offline   Reply With Quote
Old 11-05-2013, 09:07 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How do you know the ground is hot?
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (11-05-2013)
Old 11-05-2013, 09:10 PM   #3
Rewards Points: 13,694
How are you checking it, and with what?
Old 11-05-2013, 09:11 PM   #4
Licensed electrician
Rewards Points: 1,608
If the ground is truly hot it should be tripping the breaker.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Bobka (11-10-2013), gregzoll (11-05-2013)
Old 11-05-2013, 09:34 PM   #5
Because I get lit up by it everytime I touch it, even with the breaker off. I replaced the breaker because I thought it was bad...I went in to replace the dishwasher, so I flipped the breaker and it was still hot. I ended up flipping off every breaker in the house and the dishwasher was still hot. Had an electrician come out and he said it was fine. Went to install the dishwasher and got lit up but finished the install anyway.
Next day, resident says shes getting shocked at the kitchen sink. I look under the sink and see the disposal outlet box sticking out of the wall 1/2 inch. Im thinking ok water may be running down the wall under the sink when she does dishes and hitting the outlet. I flip the breaker to the disposal and begin pulling the outlet out of the wall. It lights me up. I use my beeping voltage tester to test and it says hot even though my plug-in tester and multi-meter says not hot.
Mess around some more and get shocked some more and I realize its the ground thats hot. Then I started thinking probably same thing with the dishwasher and yep. The electrician didnt find it because he never checked the ground.
Old 11-06-2013, 06:29 AM   #6
k_buz's Avatar
No, it does not imply that the ground is connected to something hot. It sounds to me that you have a bad grounding system and the utility neutral has been compromised. Usually you see other symptoms if a neutral is going bad.
I've also heard of this when a water heater goes bad.
Call a qualified electrician, not a handyman that knows a little about electrical or someone off Craig's List. They will need to be able to "see" the voltage. Then they will turn off breakers one by one till the voltage goes away. If it doesn't, that suggests that something outside of the building is causing the problem.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
electures (11-06-2013), gregzoll (11-06-2013), Speedy Petey (11-06-2013)
Old 11-06-2013, 06:51 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Throw away the no contact detector? That is absurd. That is the first thing to pull out for the average maintenance man. Is it hot or not is great to know before you start jambing your fingers in a box to pull out the wires for inspection.
I would turn off every breaker for that apartment then check both locations to see if they are still energized. Just in case they were miss wired to the wrong panel. (it happens) If not then turn breakers back on one at a time and check both locations each time until you verify for certain which breaker(s) are involved just in case they are mislabeled in the panel. (it happens)
If indeed your ground wire is hot at these locations you have two issues at for now unknown locations.
  1. The ground is not making it back to your service panel
  2. It has come into contact with the hot wire.
Happy hunting.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Philly Master (11-06-2013)
Old 11-06-2013, 07:12 AM   #8
Rewards Points: 774
Nope, if the ground is open at some point and energized....
Know A Little is offline   Reply With Quote
Old 11-06-2013, 08:36 AM   #9
Rewards Points: 756
He said that he turned off all of the breakers, but did not indicate that they were ALL off at the same time. This is an issue that confuses a lot of people (then they call me). If there is a backfeed, then you need to get the right combination of breakers to kill power to the circuit. Shutting off any single breaker won't do it.
This is one possibility in the OP's case. Again, not enough data to know.
Mark
busman is offline   Reply With Quote
Old 11-06-2013, 08:52 AM   #10
Rewards Points: 212
Sounds like a lot of guessing without enough facts. Why not have the OP call in the licensed electrician and participate/watch what the licensed electrician does to solve the problem?
Then have him tell us the procedure that actually worked or identify the root of the problem.
orange is offline   Reply With Quote
Old 11-06-2013, 10:15 AM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Lot of good advice from our professional electricians. Just because you are getting a buzz doesn't mean it is 120 volts. You need a voltage meter so you can measure the voltage. It could be any number of things such as bad neutral connection at the service or sub-panel. Loose terminations on the service. Compromised Grounding electrode system. Nail driven into the wire maybe shorting it out.
Are both appliances fed from a multi wire branch circuit? Do the circuits share a common junction box anywhere?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-06-2013, 03:28 PM   #12
electures's Avatar
Originally Posted by jeffnc
Explain exactly what you mean by "bad" and "compromised".
Poor/loose/corroded/.
The Following User Says Thank You to electures For This Useful Post:
Old 11-06-2013, 06:33 PM   #13
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
some where someone has used a Ground for a neutral ....
turn off breakers till you get NO current in the ground wire ....
"QUALIFIED"
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-06-2013, 06:40 PM   #14
Rewards Points: 516
if this is an apartment complex .. your issue may be bigger ...if you shut off all the breaker to the apartment you'll need to kae the panel cover off .... to see whats going on there ..
if you still have an issue ht the main breaker off to the apartment ...see if that does it if not report back ...
Old 11-06-2013, 06:56 PM   #15
dmxtothemax's Avatar
Rewards Points: 5,346
Have you tested the earth line with a proper testing instrument,
P.S. a volt stick is NOT a proper test instrument !
Even good quality meters can give eronious readings sometimes,
because they generally have a high input impedance.
Test it with a anologue meter, like this -
Or load the line with a real load, like a test lamp.
If it goes away, then it's PHANTOM VOLTAGE
Not unusual in modern instalations,
Check the integraty of your earthing system.
But its not unusual for small currents to circulate
in large instalations.
Some times the cause can be in a neighbours instalation.
I don't think that problems like this are easily sorted out by
in experienced personnel, as it takes a lot of understanding
of complex electrical systems.
So keep asking questions.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Help :) electricians moved insulation ober76 Insulation 16 10-10-2011 10:28 PM
Advice needed on Electricians Tafe course? Daveb2311 Off Topic 3 08-01-2010 08:07 AM
Electricians choice? Thurman Electrical 6 09-21-2009 05:04 PM
Any electricians (espicially from PA)? I have a very quick question... sofakng Electrical 8 04-01-2009 02:47 PM
Any electricians out there? Panel upgrade! roncon Electrical 1 06-19-2005 12:38 PM
