QO Quad? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 02:31 AM   #1
Rewards Points: 160
QO Quad?
I'm getting conflicting stories. I need a 30A 220 and two 20 A 110 circuits in one QO quad breaker. (Yes, I should have bought a larger subpanel. Hindsight is great.) Does Square D make them?
philS is offline   Reply With Quote
Old 02-20-2013, 02:47 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Doubt a home center would have them. Try checking a supply house that deals in sq d.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-20-2013, 06:30 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't think I've every seen such a breaker from Square D. That doesn't mean that they don't make them.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (02-20-2013)
Old 02-20-2013, 07:34 AM   #4
kbsparky's Avatar
Type QO breakers are not available in a "quad" configuration.
Some older ones (over 30+ years ago) were available in double-2-pole configurations, but nothing has been recently produced.
Get a larger sub-panel, or change over to the Homeline stuff.
-KB
Old 02-20-2013, 08:10 AM   #5
Rewards Points: 12,830
How about adding a subpanel?
Old 02-20-2013, 09:15 AM   #6
kbsparky's Avatar
Yes, if that is easier you could simply add another sub-panel leaving the others intact.
-KB
Old 02-21-2013, 12:40 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Histortywise., I know the QO series I never did see them come in quad verison at all so I really doubt if they ever show up like that.
But run of mill single pole tandems of course I have see it.
Merci,
Marc
Single Pole Breaker VS. Quad Breaker Livewire78 Electrical 37 11-28-2012 09:26 AM
Can't get f-connectors onto rg-6 quad cable DoctorWho Electrical 25 08-29-2012 11:06 PM
Quad breaker, help...... Ralph III Electrical 14 02-02-2012 09:18 PM
Quad breakers-- wmmurphy Electrical 9 10-23-2010 09:47 PM
Anyone use OSI Quad on #30W asphalt felt? kooshball Building & Construction 0 12-06-2009 12:35 PM
