QO Panel No Tandems? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 07:44 AM   #1
cj133's Avatar
Rewards Points: 318
QO panel no tandems?
So, I'm almost out of places to add circuits and I decided to look into what options I have. According to the label inside my panel all 20 locations do not accept tandems.
Anyone know why this is? I realize knowing why won't change anything but I'm curious what the difference between a 20A tandem and a 40A single is.
The one double breaker in the picture is from a stove circuit, which is what is wire nutted off on the left side so those are my last 2 locations open. The other wires that are disconnected on the right side are from a dryer circuit. In 2011 I installed natural gas in the house and converted the appliances as well. Part of me thinks I should move these into a sub panel and reconnect them for possible future use, though it seems most people think that's a waste.
So, two questions.
I'm thinking my only option if I want more is to add a sub panel. What is the largest sub panel I should add to this? Part of me says to ditch the stove and dryer circuits and re-use the 40A breaker from the stove to run the sub panel.
My panel is missing the screw to bond the neutrals to the box. In place of it I have a piece of 6 AWG copper going from a neutral terminal to one of the grounding bars but I would like to make things right. What type of screw do I need for this? I'm guessing some zinc plated machine screw from Homer isn't correct.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-18-2014, 09:31 AM   #2
cj133's Avatar
Rewards Points: 318
Actually nix the 40A B.S.
Seems like the smart move is to buy a 100A subpanel and pony up for a new 100A breaker.
The price difference between a 60A and 100A QO breaker is interesting. $16 vs $56.
Old 07-18-2014, 01:13 PM   #3
Master Electrician
Rewards Points: 3,964
Tandems are available for QO panels although the panel may not be listed for their use.
http://images.search.yahoo.com/image...mdsmll&fr=ipad
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
cj133 (07-18-2014)
Old 07-18-2014, 01:19 PM   #4
cj133's Avatar
Rewards Points: 318
Yeah, that's the issue.
My panel won't accept the hook they have.
Any idea why this is? What is the difference between a tandem 20 and a 40A single as far as the panel is concerned?
Old 07-18-2014, 01:49 PM   #5
Oso954's Avatar
Rewards Points: 1,636
It is not a comparison of a single position, it has to do with limiting the total current in the panel. You don't want someone replacing all the 15 or 20 amp breakers with tandem 20's.
40 amp singles (120V) are not commonly used in residential wiring. The 40 amp stove breaker that you talked about in your OP should be a 2 pole (240V).
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
cj133 (07-18-2014)
Old 07-18-2014, 01:51 PM   #6
Master Electrician
Non-CTL breakers won't have the hook.
The Following 2 Users Say Thank You to brric For This Useful Post:
gregzoll (07-20-2014), micromind (07-18-2014)
Old 07-18-2014, 01:59 PM   #7
cj133's Avatar
Rewards Points: 318
Yep it is,
However I assumed you could get single pole 40A ones. We all know what happens when we assume.
Looks like 30A is the highest standard single pole QO I can find.
Old 07-18-2014, 02:05 PM   #8
cj133's Avatar
Rewards Points: 318
I've heard about those.
What is the reason for the CTL feature?
Old 07-18-2014, 02:07 PM   #9
Master Electrician
Circuit limiting.
40 amp single pole breakers are readily available.
cj133 (07-18-2014), micromind (07-18-2014)
Old 07-18-2014, 02:15 PM   #10
cj133's Avatar
Rewards Points: 318
Circuit limiting.
Interesting.
Why does Square D not allow standard tandems in my panel, but does allow them in others?
My only guess is physical room for wires and or heat dissipation. If that's the case isn't going around that dangerous?
Currently considering a 6POS 12 circuit QO panel and a few feet of 6-3 copper wire. Seems like the better route, no?
Old 07-18-2014, 02:30 PM   #11
Master Electrician
Interesting.
Go for it.
Old 07-18-2014, 07:59 PM   #12
Licensed electrician
Rewards Points: 1,876
They did not pay for the panel to be listed for tandems. Simple economics.
Non-ctl breakers are for replacement use only. Panels have been CTL rated for many years.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Old 07-18-2014, 07:59 PM   #13
Rewards Points: 1,832
You could get away with none CTL tandems, but I agree this panel isn't listed for that. I know, I find it silly that panel makers and NEC cod panels put such hard restrictions on panel circuits.
Sub panel would be the complaint route.
Jump-start is offline   Reply With Quote
The Following 2 Users Say Thank You to Jump-start For This Useful Post:
Old 07-18-2014, 08:59 PM   #14
Idiot Emeritus
Rewards Points: 1,492
The Square D non-CTL tandem breakers do have a rejection feature that will not allow them to be used with panels that are not designed for tandems.
They'll fit some panels but not all.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
Jump-start (07-18-2014)
Old 07-18-2014, 09:03 PM   #15
Idiot Emeritus
Yep it is,
Square D makes single pole QOs in 10, 15, 20, 25, 30, 35, 40, 45, 50, 60 and 70 amp.
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 04:09 PM
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
