Q: Regarding Ohm's Law Re: AC - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2007, 11:12 AM   #1
Q: regarding ohm's law re: AC
Hi.
I have a hobby project which requires a small amount of heat, by which to operate an LTD Stirling model engine.
One watt of heat energy would suffice. I'll use a metal cased wire wound resistor.
Q: I don't know how to calculate the resistor's value for the source 120V AC current.
Like said, I'd like to make roughly 1W of dissipation in the resistor. What would be an appropriate value, please?
Thanks for any answers,
Reid
Btw:
Stirling models can be seen at various places on the net.
I got mine from Kontax UK; the KS90 hand-held low temperature differential stirling.
image of the model:
http://img394.imageshack.us/img394/4646/bfla9.jpg
the resistor is to be mounted to a sub-plate (aluminum disk),
and the model sits atop the sub-plate.
Reid is offline   Reply With Quote
Old 07-16-2007, 11:58 AM   #2
Agent 000
SecretSquirrel's Avatar
1 Watt / 120V = .00833~ Amps
120V / .00833 Amps = 14,405.8 Ohms
SecretSquirrel is offline   Reply With Quote
Old 07-17-2007, 11:36 PM   #3
retired
I would suggest you get a 1 to 3 watt 12v dc wall wart (power adapter) and use a 144 ohm resister. For a hobby setup like you're doing 12v will be a h*** of a lot safer to play with. Jerry rigging a heater using 120v is courting with disaster, if not for you, then for your engine!
dmaceld is offline   Reply With Quote
Old 07-19-2007, 02:32 PM   #4
Thank you both! Say, yes, the wall wart would be "safer", agreed, a bit wasteful in losses. Still best, I suppose--the low ohm resistor would be most robust.
Only if I can get a metal encased, high value resistor of the heat-sink type, will I go the direct-drop way. Of this sort:
http://www.rcd-comp.com/rcd/rcdpdf/600-FA018.pdf
Secret Squirrel, does your calculation include/allow for the RMS heating power of AC current?
Wait....dummy here now presumes "120VAC" is equivalent in resistance heating to 120VDC.
Is that the case? (thanks for bearing with me).
With appreciation,
Reid
Old 07-19-2007, 02:49 PM   #5
Agent 000
Yes... figured as RMS. Peak to peak is a different scenario.
Old 07-19-2007, 03:13 PM   #6
retired
Looks like those would be a bit pricey to me. Wire wound ceramic encased resistors that will give 1 watt of heat are mere pennies, well maybe a hundred or two, at Radio Shack.
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 09:27 AM
