PVC Size - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 03:34 PM   #1
PVC size
What size pvc is needed by code to sleeve #1 SER through. Run is indoor and 40 ft
ssmag is offline   Reply With Quote
Old 08-13-2012, 04:14 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You could get by with 1 1/4" but I would go at least 1 1/2" to make it easier.
wirenut1110 is offline   Reply With Quote
Old 08-13-2012, 05:19 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If you are only sleeving the SER for protection, if it fits its OK. But certainly bigger makes it easier to pull the cable in.
Coastal South Carolina
Old 08-13-2012, 05:36 PM   #4
Master Electrician
Rewards Points: 3,756
To be code compliant 1.5" minimum.
brric is online now   Reply With Quote
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Aluminum wire size/ guage / amps? walt1122 Electrical 17 07-30-2008 11:44 AM
