Old 08-14-2012, 05:39 PM   #1
PVC Sch 80 to metal LB - grounding necessary?
Is there any NEC code issue when using a metal LB in between runs of PVC?
I'm using about 5' of Sch 80 PVC outdoor, buried, as it leaves from the crawlspace of my home and comes up in through the concrete slab of a workshop. The LB will be used to send the wire out from the crawl and down to the trench. Sch 80 is being used because of possible impact at a sidewalk area. I don't think they make a Sch 80 LB so I picked up a metal LB with an adapter.
Thanks for the help.
RM575 is offline   Reply With Quote
Old 08-14-2012, 06:28 PM   #2
Master Electrician
PVC pipe fittings fit both schedule 40 and schedule 80 pvc pipe. The inside diameter of 80 is smaller.
brric is offline   Reply With Quote
Old 08-14-2012, 07:29 PM   #3
Originally Posted by brric View Post
PVC pipe fittings fit both schedule 40 and schedule 80 pvc pipe. The inside diameter or 80 is smaller.
Thanks for the reply. But, I'm wondering about any requirement about strength or durability with the PVC pipe fitting when installed in areas where it could be hit by something like close to a walkway. I thought that's why schedule 80 is required in those areas. So, if schedule 80 pipe is required, do the PVC fittings such as LB's have to be Sched 80 too? Is there such a thing as pipe fittings (LB's) in Schedule 80? Or are pipe fittings not required to be classed that way?
Old 08-14-2012, 08:37 PM   #4
Lic Electrical Inspector
electures's Avatar
The metal LB has to be grounded.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 08-15-2012, 11:08 AM   #5
Thank you for the reply. Would you have a NEC section I can look up? I have the 2008 edition.
Also, is there such thing as a Schedule 80 PVC LB?
Or, would you know what the right fitting or method would be to send the conduit into the crawlspace from a trench where the conduit would be exposed about 12" as it transitions from the side of the home to the trench at a walkway?
Old 08-15-2012, 11:47 AM   #6
Without more looking, I would think that 250.4 (A) (4) would be applicable. There may be more
Anti-wingnut is offline   Reply With Quote
Old 08-15-2012, 12:35 PM   #7
Thanks. I looked that up and it mentions ..."Bonding of Electrically Conductive Materials and Other Equipment."
So, lets say that I want to use a PVC LB in this area. Is there an LB, besides metal, that would be allowed in this area? Is there such a thing as Schedule 80 PVC LB? I've searched for a PVC LB with that rating and can't seem to get this answered.
Old 08-15-2012, 01:50 PM   #8
Does anyone know of any PVC LB's with a rating of Schedule 80?
Old 08-15-2012, 03:35 PM   #9
Call Carlon:
Ready to place an order? Questions?
Call Us: (877)-268-3700
bob22 is offline   Reply With Quote
Old 08-15-2012, 04:04 PM   #10
I found the answer. The Type LB conduit#5133665, made by Cantex, is interchangeable with Schedule 40 and Schedule 80. So, the answer is "yes" they do make a pvc Type LB fitting for Schedule 80 pvc pipe. I emailed their tech dept at techinfo@cantexinc.com and their rep replied that their LB's are interchangeable. Carlon most likely has an equivalent product.
Old 08-15-2012, 05:04 PM   #11
That answer was already given to you in this post.
Or were you looking for a LB with the wall thickness of schedule 80? I don't think there is such a thing.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
brric (08-15-2012)
Old 08-15-2012, 05:11 PM   #12
The "fit" is not my concern.
I was looking for an LB that will pass inspection for the durability factor. As I understand it, Schedule 40 pipe cannot be used where it might receive impact damage, such as near a walkway.
So, it is looking like the PVC LB's made are for both pipe, schedule 40 and 80 pipe. There doesn't appear to be a PVC LB dessignated as Schedule 80. I guess the inspector will only be concerned about the pipe and not the LB.
Old 08-15-2012, 06:58 PM   #13
Master Electrician
What type of impact is likely at a walkway?
Old 08-15-2012, 07:31 PM   #14
Lawnmower, bicycles, etc. basically anything that can be pushed or roll into the pipe that may damage the pipe and it's conductors within the pipe.
cable line grounding amakarevic Electrical 56 05-15-2012 10:22 PM
electric grounding bar in main panel steve gregory Electrical 13 01-22-2012 03:20 AM
Grounding Metal Boxes Instantlegend Electrical 8 01-16-2012 11:10 PM
metal boxes and grounding jrocker1 Electrical 5 02-14-2010 09:01 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
