Pvc Run - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 11:09 PM   #1
Rewards Points: 512
pvc run
I'm needing to bring pvc from the backside of an outdoor brick wall over the top, and down to ground, because I don't want to have to drill through it.
The backside grade is about 12" below the top of the wall, while the inside grade drops to about 4'. After coming over the top, I can run the rest about 6' underground to the building.
My plans are to simply attach the PVC (sched 80) to the backside of the wall with straps, and then bring it over the top.
The dilemma is what fittings are available to make this work. The wall is about 6" thick.
Old 06-15-2012, 06:23 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Any combination of LB fitting and junction box should get you where you need to be.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-15-2012, 06:24 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
LB's would work, but anything you do in this application will look like dog do.
Old 06-15-2012, 11:59 AM   #4
Rewards Points: 126
I would try and go under or through it. Like k buz says. It will look like dog do.
Old 06-15-2012, 02:49 PM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I have to agree with the two previous posts. Going over the top will look like crap.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-15-2012, 08:48 PM   #6
rrolleston's Avatar
True will look like dog do it probably could be done with a tool rental. Extra money on fittings conduit and wire could cover some of the tool rental and have a cleaner install. Possible you could just buy a core bit and chisel if you have at least a 1/2" drill. Then just seal around pipe with hydraulic cement.
Old 06-15-2012, 11:35 PM   #7
Rewards Points: 512
Thank you, guys.
Old 06-16-2012, 08:44 AM   #8
Rewards Points: 320
This is an underground service to a shed/outbuilding? What about another outside wall? Does the brick go all the way around the house? You may be able to come out on another side and then just trench a little further.
teamo is offline   Reply With Quote
Old 06-16-2012, 09:37 AM   #9
rrolleston's Avatar
A really cheap option if the brick is the hollow type. Just punch a hole with a decent size hammer and repair with cement.
