PVC Recepticle Box Tabs Not Holding Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 06:44 PM   #1
Rewards Points: 77
PVC recepticle box tabs not holding cable
This is my first stab at wiring so I am wondering if I am doing something wrong here. The PVC boxes that I bought at Home Depot have little knock out tabs that don't hold the cable in place like they should. Here they are in this top picture. When I break one of the two tabs that hold them in place they just dangle there and they don't have any holding power to hold the cable in place. Am I missing something or is this OK? I know the cable won't move once the wires are connected but I wouldn't think this will pass inspection since the tabs are not holding them. The 2nd pic is what they look like after I run the cables in. They look like they aren't there, but they are, dangling on the inside, not supporting the cable like they should.
epeterson777 is offline   Reply With Quote
Old 02-06-2009, 06:52 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
No, they're supposed to be like that. It is fine. However, I will point out that one wire looks like it too close to the edge of the stud.
wirenut1110 is offline   Reply With Quote
Old 02-06-2009, 09:08 PM   #3
remodeling pro
Some of the plastic boxes have a different style of entry, where there is a heavier spring type of plastic tab that prevents the wire from being pulled back out, some are like yours, where it is a complete break away. As long as you staple the wires within the required 8" of the box, you will be OK.
troubleseeker is offline   Reply With Quote
Old 02-06-2009, 10:03 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by epeterson777 View Post
........ When I break one of the two tabs that hold them in place they just dangle............
I've never had that happen to me. Use a flat blade screwdriver to gently pry open one side of the tab on the next box Before it's installed. Then insert the flat blade screwdriver into the opening to be sure the tab maintains pressure. If the Tab dangles then there is a manufacturing defect.
If more likely it's OK, Then you used more force the necessary to open the tab. They don't like to be opened by slapping the end of a screwdriver against the tab.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-06-2009, 10:18 PM   #5
No. These Carlon boxes have no clamps. It's just a KO.
220/221 is offline   Reply With Quote
Old 02-06-2009, 10:53 PM   #6
Electrician
I agree, staple required within 8" of box and move on...
chris75 is offline   Reply With Quote
Old 02-06-2009, 11:12 PM   #7
Tool Geek
PaliBob's Avatar
........... but they are, dangling on the inside, not supporting the cable like they should.
220/221
The O.P. by EP777 has this Pic which makes it very clear that there are no clamps in the box. I said that if the Tabs break off then most likely there is operator error but if the tabs just break off then there may be a mgf defect
Chris75,
This discussion was about the box tabs. The O.P. clearly shows the cable clamps in the stud
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-07-2009, 12:16 AM   #8
Rewards Points: 77
The tabs are still in the box, you can't see them in this picture because of the shadows. All the double gang boxes that I bought have different tabs that do have the spring loaded pressure to hold the cable in place, but the single gang boxes no matter how lightly I break them open, they will dangle. There just isn't enough plastic there to hold them up from dangling, but like everyone else said I am just going to staple the cable within 8" and move on.
Old 02-07-2009, 09:00 AM   #9
Electrician
Thats because single gang boxes dont require cable support inside the box.... so the manufacture does not supply it.
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
