Pvc Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 10:19 AM   #1
pvc pipe
can pvc conduit be run in a commercial building
FLGATORTOM is offline   Reply With Quote
Old 07-30-2009, 10:30 AM   #2
Tired & Dirty
Rewards Points: 83
Hi Flgatortom,
Can use pvc as long as it is the grey electrical type and a ground wire is included, at least in these parts ya can, don't know about other areas.
evapman is offline   Reply With Quote
Old 07-30-2009, 10:35 AM   #3
Rewards Points: 2,350
You cannot use PVC in an are used as plenum air return, such as a ceiling designed as such. Sometimes a tile ceiling will be used as the actual return air duct for the air conditioning system, and no PVC can be used in such a space.
Old 07-30-2009, 11:16 AM   #4
Registered User
Termite's Avatar
Very true, and very common for the above-ceiling plenum to be used for R/A in commercial buildings!
Old 07-30-2009, 11:32 AM   #5
Rewards Points: 240
When I worked commercial in S. Florida (high rise condos) we used PVC for the first floor underground and in slabs. After the first floor we transitioned to EMT.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
