PVC Hinged Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2014, 02:21 PM   #1
Rewards Points: 455
PVC Hinged Conduit
anyone know if there is a product out there for mostly 1/2" and 3/4" pvc conduit for replacing breaks without having to remove conductors ???
Cletis is offline   Reply With Quote
Old 06-01-2014, 03:18 PM   #2
Licensed electrician
Rewards Points: 1,892
Yes.
Old 06-01-2014, 03:33 PM   #3
Rewards Points: 455
Originally Posted by Jim Port View Post
Yes.
I'll rephrase my original question then
anyone know if there is a product out there for mostly 1/2" and 3/4" pvc conduit for replacing breaks without having to remove conductors ??? If yes, can you post a link.
I already know about this stuff and the like but it only goes down to 1"
http://www.conduitrepairkit.com/
Old 06-01-2014, 03:50 PM   #4
Rewards Points: 1,300
Before you got banned from the pro electric forum, you claimed to be a pro. As a pro, I would think you should know about this stuff.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Jim Port (06-01-2014)
Old 06-01-2014, 04:33 PM   #5
Rewards Points: 455
Yes, On top of the 1000 page NEC I also memorized every imaginable electrical part out there. I must have not memorized this one
Old 06-01-2014, 06:47 PM   #6
Rewards Points: 774
Clete, you are smart enough to figure this out, for 3/4" cut a piece of 1" to length, cut it in half heat and form fit if necessary and apply glue. FOr 1/2" use 3/4" pvc and repeat.
Know A Little is offline   Reply With Quote
PVC conduit questions powertoolguy Electrical 4 08-28-2013 06:30 AM
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 10:34 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
