PVC Conduit And Steel Box Question???? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2008, 08:07 PM   #1
PVC Conduit and steel box Question????
Is it legal and okay to use PVC conduit ran to galvanized metal junction boxes?
houstonbrama is offline   Reply With Quote
Old 08-05-2008, 09:30 PM   #2
Idiot Emeritus
Rewards Points: 1,492
It's very common to use PVC and metal boxes in block walls.
Simply glue a male adapter onto the pipe, and use a locknut inside the box, just as you would with EMT. You'll need to ground the box. Most, if not all, have at least one tapped hole for a ground screw.
Rob
micromind is offline   Reply With Quote
Old 08-05-2008, 11:29 PM   #3
That's great news. Do I ground the box with the same ground that I am pulling for my plugs and switches? Oh and thanks for the info!!!
Old 08-06-2008, 12:00 AM   #4
Cow
Yes.
Cow is offline   Reply With Quote
Old 08-07-2008, 12:56 PM   #5
Rewards Points: 80
Anytime you are using PVC you must pull a ground wire. Regardless if the box is metal or plastic.
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
conduit and fittings analogmusicman Electrical 16 05-10-2008 01:30 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 03:16 PM
Question about grounding othermatt Electrical 8 03-25-2008 05:21 PM
Copper pipe for conduit? ricemg Electrical 4 01-23-2007 06:04 PM
