-   -   PVC Conduit and steel box Question???? (http://www.diychatroom.com/f18/pvc-conduit-steel-box-question-24790/)
houstonbrama 08-05-2008 07:07 PM
Is it legal and okay to use PVC conduit ran to galvanized metal junction boxes?
micromind 08-05-2008 08:30 PM
It's very common to use PVC and metal boxes in block walls.
Simply glue a male adapter onto the pipe, and use a locknut inside the box, just as you would with EMT. You'll need to ground the box. Most, if not all, have at least one tapped hole for a ground screw.
Rob
houstonbrama 08-05-2008 10:29 PM
That's great news. Do I ground the box with the same ground that I am pulling for my plugs and switches? Oh and thanks for the info!!!
Cow 08-05-2008 11:00 PM
Yes.:thumbsup:
J. V. 08-07-2008 11:56 AM
Anytime you are using PVC you must pull a ground wire. Regardless if the box is metal or plastic.
