Old 05-08-2009, 10:37 PM   #1
PVC Conduit Question
Just wondering is rigid pvc conduit the same or equal to schedule 80. I noticed the other day the box for our septic pump alarm has rigid pvc going from the box into the ground where it goes to the tank and has a piece of schedule 40 from the box into the house totally above ground.
Plumbvoltage is offline   Reply With Quote
Old 05-09-2009, 03:32 AM   #2
" Euro " electrician
frenchelectrican's Avatar
There is the diffrence between the shed 40 and shed 80 is wall thickness.
Overall the extreal diameter is the same for both 40 and 80 but interal diameter that will change a bit depending on the numbers of conduct it will be using.
Merci,Marc
Old 05-09-2009, 11:40 AM   #3
J. V.'s Avatar
Both are ridged. Schedule 40 and 80.
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 07:07 PM
#3 AWG Copper SER / PVC Conduit Question djejay75 Electrical 4 12-12-2008 12:40 AM
Electrical size conduit question pauls Electrical 12 12-03-2008 10:22 PM
Barn wireing and conduit question???? houstonbrama Electrical 8 07-09-2008 02:12 AM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 04:55 PM
