PVC Conduit Into Metal Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 09:25 PM   #1
zpm
yeah, right
PVC conduit into metal box
What's the proper way to connect PVC conduit to a metal box. Male adapter with locknut?
zpm is offline   Reply With Quote
Old 05-24-2009, 09:56 PM   #2
Idiot Emeritus
Rewards Points: 1,492
I don't know how many thousands of MAs and locknuts I've used over the years. The locknut can be either plastic or metal.
It's very common around here to use PVC with metal boxes in block walls. I usually put the MAs into the boxes beforehand, and cut and glue the PVC to fit.
Rob
micromind is offline   Reply With Quote
Old 05-25-2009, 01:17 AM   #3
Is this a trick question?
I don't know any other logical way.
I guess you could use a female adapter and a chase nipple.....but I don't know why you would.
A rigid compression connector would work too....but again, I don't know why you would use it.
220/221 is offline   Reply With Quote
Old 05-25-2009, 01:58 PM   #4
Electrical Contractor
kbsparky's Avatar
A male or female (terminal) adapter with the appropriate lock ring or chase nipple works just fine.
You can also use a box adapter connected to a coupling:
Old 05-25-2009, 02:17 PM   #5
Rewards Points: 58
Don't forget you need an EGC, regardless how you connect the PVC to the metal box.
Old 05-25-2009, 03:14 PM   #6
zpm
yeah, right
Yeah. And you bit on it.
Considered that, but if the box ever needed to be replaced it would require cutting up the conduit.
Probably not listed for that use.
I mainly wasn't sure if I had to use plastic locknuts, but I guess it doesn't matter.
Thanks.
Old 05-25-2009, 05:37 PM   #7
Idiot Emeritus
Any type of locknut will work. There's no code that requires plastic locknuts with PVC.
Rob
Old 05-26-2009, 01:36 AM   #8
liscenced electrician
Rewards Points: 538
I didn't even know they made plastic locknuts . Your not talking about plastic bushings are you
jimmy21 is offline   Reply With Quote
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 09:31 PM
