PVC Box And Gfi - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 07:50 AM   #1
Rewards Points: 225
PVC box and gfi
Couple of questions:
1) Ok to use PVC outlet box for GFI
2) The PVC box does not have any clamps inside the box to secure the wire.
Used a white plastic staple to the stud that the box is secured to. The wire inside the box if pulled on can move up and down. Not sure if using a metal staple would be better so the wire does not move. The plastic staple is about 5" or so from the box. Read that when using pvc boxes there is no clamp and the staple holds the wire. The wire seems loose after using the staple. Is this ok?
Thanks for any help.
gt1935 is offline   Reply With Quote
Old 08-03-2013, 08:00 AM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
yes ..
min code is 8" from the box with no clamp ..
when you put the outlet in it should be fine ..
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-03-2013, 08:33 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Those white plastic 2-nail staples SUCK!
If you use metal staples, even the plastic coated or throated ones, your cable will be MUCH more secure. Just don't drive them to far.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Kyle_in_rure (08-03-2013)
Old 08-03-2013, 10:01 AM   #4
Electrical Enthusiast
Rewards Points: 504
I was about to buy some of those to try them out. Glad I didn't.
Kyle_in_rure is offline   Reply With Quote
