Puzzle... Can You Solve? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 03:27 PM   #1
Puzzle... can you solve?
I need to install a new 20A circuit. My 200A panel seems quite full. Here is a picture
Rotate head to your left
At the bottom left, there is an unused 50A breaker, taking up 2 spaces. Can I use that, or should I leave that alone? What is it even there for? A subpanel?
Next question:
I have 2 switches in the walls at separate locations that SEEM to serve no purpose, though they are wired. They don't SEEM to control anything. Here are the pictures:
Sorry all pictures at the bottom - having trouble spacing our my post correctly. Anyways..
The first picture, the switch on the right controls a ceiling fan. The removed one does .......?
The second picture, same thing, except switch controls hallway lights (1 of 3 switches that control those lights). Removed switch does.....?
I have 1 - 15A breaker (bottom right of panel) that has 12/2 connected to it, and goes .... somewhere..... but for the love of God I have no idea what it does if anything. House panel labeled poorly (by others). I was thinking maybe it had something to do with those mystery switches, but I couldn't get any reading with my MultiMeter on the 2 mystery switches (not sure if I even am using it correctly however).
Any ideas? Any help at all would be wonderful!
Puzzle... can you solve?-electrical.jpg   Puzzle... can you solve?-switch-1.jpg   Puzzle... can you solve?-switch-2.jpg
Rxotik is offline   Reply With Quote
Old 03-10-2013, 03:40 PM   #2
Licensed electrician
Rewards Points: 1,876
I can tell you you should not have the Square D breakers in the GE panel.
The first switch is a 3 way.
Old 03-10-2013, 03:43 PM   #3
Yes I see the different breakers in the panel now. Ok, that must have been done by the previous owner.. Thanks for pointing that out.
The first switch only controls a ceiling fan. The one hanging out is a mystery....
Thanks..
Old 03-10-2013, 04:43 PM   #4
Oso954's Avatar
Rewards Points: 1,650
Does your ceiling fan have lights on it ?
If not, the switches might be a 3 way set up to control lights on a previous ceiling fan.
Oso954 is online now   Reply With Quote
Old 03-10-2013, 04:46 PM   #5
Rewards Points: 992
If the 50a breaker is not connected to anything you can pull it out and put in your 20a. May have been for a subpanel, welder, stove....
Your extra switch could be for a light in the fan. Just a wild guess.
Turn the mystery breaker off and eventually you may find something doesn't work. It took me 10 years to figure out that a mystery switch controlled an outlet I never used.
Toller is offline   Reply With Quote
Old 03-10-2013, 04:47 PM   #6
Hmmm.
No lights on the ceiling fan, and I believe the fan is original with the house, built in 2001.
Very basic, white, plain jane fan. Don't think previous/original owner picked that out and put it there, 15 feet in the living room.... pretty sure its original.
Thanks for the reply...like I said, its a mystery!
Old 03-10-2013, 04:50 PM   #7
I think I will do that...
I was just hoping to USE it for the new circuit and not take up the 50A spot just yet if I didn't have to. But I'll definitely turn it off for now...
Thanks for your reply!
Old 03-10-2013, 09:29 PM   #8
Electrical Enthusiast
Rewards Points: 504
Keep in mind that if you remove that double-pole 50 amp breaker to install your 20 amp circuit, you will need to buy a blank filler plate to fill in the blank space in the panel left by one of the breakers.
It is quite likely your "mystery switches" are for an optional light on the fan. I see it done frequently.
Kyle_in_rure is offline   Reply With Quote
Old 03-10-2013, 09:42 PM   #9
" Euro " electrician
frenchelectrican's Avatar
The mistery switches what it is there that is common used for lights with the ceiling fans and I have done that pretty often.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Rxotik (03-10-2013)
Old 03-10-2013, 10:24 PM   #10
I can see that as a possibility for the one switch like that, but there are 2 like that. And the other has no ceiling fan on that circuit, just lights (hallway, controlled by 3 total switches... The mystery switch in this case is in the same box as one of the switches that control these hallway can lights).
Thanks for the electric panel guidance and your advice!
Old 03-11-2013, 07:00 AM   #11
Rewards Points: 2,516
What switch on the right? I only see switches on top and bottom. Cant you go back and rotate your photos so they are in the correct orientation. At least the one of the panel.
hammerlane is offline   Reply With Quote
Old 03-11-2013, 01:53 PM   #12
Pure Genius
Rewards Points: 150
Any other lights in the rooms with the mystery switches? If not they could be for switched receptacles
Dierte is offline   Reply With Quote
Old 03-11-2013, 03:39 PM   #13
I've checked for switched receptacles. No luck, all receptacles powered regardless of the position of the switch..
Old 03-11-2013, 03:43 PM   #14
Sorry,
I can't seem to get the photos the right orientation....
Turn head to the left
Or turn computer monitor to set on its right side!
Old 03-11-2013, 03:44 PM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Pull the 50A....put in two 20a breakers...that way you have a spare breaker.
Have you pulled down the ceiling lights/fans to see if there is a spare wire tucked into them?
Would upgrading to 200 amp service solve this problem? NancyNGA Electrical 7 03-01-2011 08:38 PM
Wiring My Thermostat...Please Help Solve Puzzle! :) IdahoGirl HVAC 31 05-15-2010 02:31 AM
GFCI puzzle analogmusicman Electrical 7 04-10-2008 05:13 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
