Putting An Outlet In The Attic - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 08:46 AM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I know many people that still call the breaker panel the fuse box. Looks like you got it right. Nice you had the extra wire left there for a receptacle.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-07-2013, 10:10 AM   #17
Originally Posted by Gac66610 View Post
Don't worry too much about the terms used, not everyone knows the difference between lighting outlets and receptacle outlets either.
What one area calls something isn't always the same somewhere else.
When I tell my guys to "go pull the main" they know I just want the main breaker turned off.
Yes check your breakers, sounds like you may have tripped one.
Just two quick questions, did you install the duplex receptacle in a box? and is it a GFCI receptacle?
Most of the time when a wire is cut in the middle, there is not enough wire to bring into a box and make connections, I obviously do not know your setup and there may have been plenty to use.
I'm not sure if its a GCFI receptacle or not, it didn't say anything about it on the package. But I did flip my breakers and everything works properly now, so thank you everyone for your help, this is quite the nice forum. Also heres a photo of my setup, just incase anyone was curious. Notice I had to use a couple feet of my own 14-2 and there is no return switch line.
http://imgur.com/LPTAiMQ
ksullan is offline   Reply With Quote
Old 02-07-2013, 10:16 AM   #18
Licensed electrician
Rewards Points: 1,744
Those splices need to be in a junction box with a blank cover.
Old 02-07-2013, 10:31 AM   #19
Missouri Bound's Avatar
Originally Posted by ksullan View Post
there is one 14-2 going into it from the switch.
Well......that's pretty much the DEFINITION of a switch leg.
Do you want it your way or the right way?
Old 02-07-2013, 10:38 AM   #20
Is that just a code thing or is it a safety issue as well?
Oh I see, I thought a switch leg included a return line from the lighting fixture..
Old 02-07-2013, 11:07 AM   #21
It is both a code requirement and a safety issue.
Old 02-07-2013, 12:48 PM   #22
Resi EC
Rewards Points: 252
The box needed, will have a two hour fire rating .... whats the fire rating of the wood next to those splices?
Gac66610 is offline   Reply With Quote
Old 02-07-2013, 03:48 PM   #23
I'm not sure what the fire rating is, how would I go about checking that?
Old 02-07-2013, 04:28 PM   #24
There is no need to check it. Put the splice in a box and install a blank cover.
Old 02-07-2013, 04:51 PM   #25
Ok, thanks for the help, man.
Old 02-08-2013, 12:20 AM   #26
Rewards Points: 512
this has to be a shot at ksullan's question
Old 02-08-2013, 02:26 AM   #27
Clown!
Hardway is offline   Reply With Quote
Old 02-08-2013, 06:48 AM   #28
Resi EC
Rewards Points: 252
Old 02-08-2013, 11:50 AM   #29
Originally Posted by gac66610 View Post
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Metal outlet box in attic space grounding BlueBSH Electrical 3 11-02-2012 04:30 PM
Question on putting an outlet under the sink svidrillion Electrical 13 02-26-2012 10:31 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
