Putting In A New Electrial Fuse Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 09:57 PM   #1
Rewards Points: 210
Putting in a new electrial fuse panel?
I believe mine is rated at 150amp and have only one fuse open. I plan on doing a Home Theater in the bonus room and want to run some dedicated 20amp lines and some dedicated 15 amp lines.
Now I'm no electrician but I ran a dedicated 20 amp line for my buddies house for his home theater and it went very easy.
I would like to know what kind of work is involved in rewiring a new electrical box? I want there to be plenty of space for the new outlets and thought I "might" be able to do it myself.
Like I said I'm not electrician but I enjoy doing things myself. Is there a certain way this needs to be done or should I just leave it up to an electrician?
If this is something that should be left up to an electrician, could I get everything installed like the new box and then have the electrician come in and wire it up to save some money?
What do ya think?
If I'm a 150amp service right now, can I or should I up it to 200amp service? I need recommendations for the new electrical panel so if someone has some ideas on what brand I should get please let me know.
imola ghost is offline   Reply With Quote
Old 09-01-2008, 10:04 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
What do ya think?
First off if you have to ask, then this is one area A DYI should not wonder.
branch circuits I can understand. You might feel comfortable in this area. but if you have to ask about service changes then you should consult with a licensed electrician. Sorry !! BOB
Old 09-01-2008, 10:12 PM   #3
Rewards Points: 210
I thought so!
I'd like to find someone that I could help with the install and learn.
Old 09-01-2008, 10:16 PM   #4
buletbob's Avatar
I thought so!
Look in the yellow pages call a few and explain what you would like to do.you might get lucky.
Old 09-02-2008, 09:42 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
I agree, although I gotta say, I doubt your find any "real" electricians who will do this, especially for a service change. It's just not worth it.
We all have a rhythm and routine. There is really nothing you can do ahead of time to save anything.
Old 09-02-2008, 10:04 AM   #6
Res Ipsa Loquitur
Is it a fuse panel or breaker panel? You have 150a panel and you need some more space. If it is a breaker panel and your panel can accept them you might be able to have a few tandem breakers in place of the full size depending on the type of panel. If I was just looking for the additional space I would consider this first, next choice a subpanel then a full replacement. You may not need to go larger than 150 depending on your current load.
handyman78 is offline   Reply With Quote
Old 09-03-2008, 03:51 PM   #7
EAP
I agree with the others. Consult with a pro at the very least.
What's to stop you from visiting your local library or HI store and picking up a book on wiring? There are several to choose from. This is a wonderful way for learning the various elements involved.
A local pro can keep you grounded (no pun intended) on local code requirements.
Good luck.
EAP is offline   Reply With Quote
Old 09-03-2008, 05:15 PM   #8
Power Gen/RS Engineer
Rewards Points: 566
According the NEC along with any local amendments...
If you're talking about doing some of the work yourself, many electricians won't want to bother with the job. Too much liability not to mention that if they find something that you have done to be in violation of the code, they will have to deal with it which means money/time wasted.
If you already have a 150A panel, chances are very unlikely that you'd need to upgrade it to 200A to cover the addition of a few 15A/20A branch circuits. Since it sounds like you are tapped out on space, one option would be to add a subpanel which could be done rather cheaply.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 09-04-2008, 11:57 AM   #9
Rewards Points: 80
Stick with the 150. They do make breakers that are two in one. Two breakers in one slot. Make sure your panel will accept this type of breaker.
Old 09-04-2008, 12:39 PM   #10
Rewards Points: 566
John-
Maybe I'm taking the OP's initial post too literally but he mentions having only one fuse available.
--> Is this a fuse or breaker panel?
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 06:02 PM
